Thin gray line tahoe build
T
thingraylinetah
Crossville Tennessee
I hope that these repairs will fix my issues because if they don't it might be bye bye tahoe. I mean I'd love to get a new 5.3 crate motor if this one dies but my wife would never allow it.
pwtr02ss
Tennessee
It was about a half a quart per week. I don't know the exact mileage.
I can't remember your exact year, but some of the earlier years had a serviceable pcv valve. If so, replace it. Could also do a seafoam treatment on the cylinders. Possibly an oil control ring stuck. Notice any smoking at start up, especially after long drives on the interstate?
T
thingraylinetah
Well gents. It ran fine for about 24 hours. Then the check engine light came back on and the gas mileage went way down again. I am going to have my son read the code when he gets home. If it comes up as a knock sensor code still. That means that it is detecting an engine knock. At which time I think it will be scrapped and gotten rid of. I guess I am just not destined to be a Tahoe owner.
You’re giving up way too easy. What brand knock sensors did you install? If they’re Dorman, there’s your problem. They’re known to fail, only go with OEM. And it could still be your MAF. I believe you only said you cleaned it? If it’s still throwing a MAF code, try replacing it with a Delphi OEM, again not aftermarket. Your lifter tick may be broken exhaust manifold bolts- check to see how many broken ones you have. I’d be willing to bet you have a few and the exhaust leaks have fooled many owners of these vehicles. These engines are pretty bulletproof.
T
thingraylinetah
Delco sensors, maf was replaced with a brand new one that was on a yukon we bought for parts. It is a Delphi one.
My wife holds the purse strings and she won't let me use any money to fix it.
T
thingraylinetah
I borrowed a different scanner and it was the knock codes again. I found out from my step son that when he installed the knock sensors and wiring for the knock sensors that the check engine light went off automatically so he didn't clear the code. I cleared it with this advanced reader. So maybe it'll stay off this time. I'm hoping it does anyway!
Did he do the rtv dam around the knock sensors?
That’s not good. Are you sure it’s not just the gauge?
T
thingraylinetah
No, it's full of oil but for some damn reason the engine is knocking. My step son said he thinks it's about to throw a rod so I got it parked for now until I decide what I want to do with it. I'd like to put a crate motor in it but I'm not 100% sure yet.
a1parrothead
