Why don’t my batteries last !!!!
Kgitti
I pay good money for batteries I think, in the $200 range, and they last me from a year to 2.5 years. I’m not talking about just my 2002 Yukon, but also our Highlander and Rav 4. These have included Interstate, AAA (real junk). Diehard Gold etc.
I live in New Mexico and my vehicles live outside in the heat but jeez, has battery quality just gone in the ******* or am I buying the wrong battery?
Miami-Dade
Moderator Supporting Member
In Miami jungle heat [all year long] I get 3 years out of a battery if I am lucky. Most times around 2.5 years or less. Been getting AC Delco batteries.
Trey Hardy
I’ve had similar luck seems like if they last 3 years it’s a miracle.
When mine finally gives out I’ll be swapping over to lithium to try out its around 450-500$ but has better constant voltage quick charge and lasts 10 years supposedly
420$ but by the time you get the box and mounting hardware your over 500$
I quit using interstate batteries
I’ve had good luck with my diehard so far
If your vehicles sit for long periods of time and then make short trips or let's say they are used daily but for short runs the batteries are going to prematurely wear out. Lots of short runs doesn't allow the charging system to completely recharge the battery. This causes the plates to build up sulfate which reduces their ability to hold a charge.
A battery tender can rejuvenate and maintain batteries used in a such a way. Down here in Florida, it was rare for a battery to last more than about 2 years before the introduction of smart charging system like those introduced in GM trucks around 2005. With EPM and RVC, the batteries last 4+ years now. Your older trucks don't have it but your Toyotas ought to, not sure.
Many years ago I switched our first line vehicles to ACDelco batteries and couldn't be happier. An inexpensive 48PS with a 30 month free replacement warranty lasted 48 months in one truck and almost six years in another.
The charging system in your GMT800s is not designed to properly charge an AGM battery. You can certainly use them, they just won't last as long as they would have in a vehicle with a charging system designed to charge and maintain them.
tom3
Walmart top battery in the big size for a Tahoe has a four year replacement warranty - when I last looked. Had good luck with their batteries overall.
Alex_M
There are much fewer battery manufacturers out there than there are battery companies - most batteries come from only 2 or 3 manufacturers.
I used to buy more expensive batteries, but found it makes little if any difference in most cases. Interstate is one that may genuinely be good - I just this past summer took an 18 year old interstate battery out of service. She was on life support, but finally gave up the ghost.
At this point, all I buy are Rural King batteries. Like $70 for a group 78 top post/side post with a handle so they fit everything and they're easy to move. They seem to last well and the price is right. I have I think 5 in rotation right now, the oldest of which is 3 or 4 years old right now which is about how long ago I switched to them. I've owned probably 8 or 9 and I think only had one die so far, and not because I treat them well.
Frankly unless it were a specific use case - lithium to save weight, deep cycle, or AGM, I wouldn't spend $100 on a battery.
Donal
Americus Georgia
Search for "12v24v intelligent pulse repair charger." These are available on amaozon for under 30.00 and on other sellers for less that 20.00. I have two and use the repair function often on vehicles that may sit unused for a couple of months.
91RS
GA
2-3 years is about all a battery lasts these days. It might last more if you have a vehicle (not these trucks) that has the battery inside the car. They’re all made by only a couple of manufacturers so the brand doesn’t matter as much.
I’ve found the cheapest batteries seem to last the longest. I bought a Napa AGM for my 08 when I put in my sound system and it lasted 2 years, it was prorated so the replacement cost me $100. The AC Delco AGM battery I put in my SS started going bad right before the 3 year warranty expired so I got that one replaced for free. The cheapest AC Delco silver battery is still going strong for about 3 years now in the other truck.
Mudsport96
40.923,-89.488. Illinois
No joke, that is all I used when I worked there in the early 2000s. And the old yellow "MAXX" batteries lasted forever. I put a couple in my dad's company vehicles and they lasted 7 or 8 years. And I had one that lasted 6 in my old Blazer, and it was shaken and knocked around, run dead a few times. But after a charge would be fine again.
Hobert
Downers Grove, IL
View attachment 421529View attachment 421530
My My we are so close. I think you need to add the Flux-Capacitor, available on ebay.
Kgitti
Kgitti
My orielly brand in my f150 is about 6 years old, the Silverado is 4 and I think the Tahoe is 3ish years old. It may be the heat, or are you short tripping alot and they don't fully charge?
Maybe. But on my Highlander I was still working full time and traveling all over the state.
Kgitti
Kgitti
If memory serves when I was a kid,
Batteries always outlasted the warranty significantly.
Kgitti
Kgitti
I’ve never heard of this. Thanks.
Scottydoggs
NJ
I just replaced one under warranty in my Yukon. It lasted 22 months.
did you at least get it pro rated on the cost of the new one?
im in NJ. it gets pretty hot here in the summer and pretty cold come winter. only time its failed on me was when i left the key to run for a hr by accident. and im only doing 4-5 miles each way to and from work, and dont work in the winter so it can sit for a week at a time. never a slow crank even.
have you checked for a power draw or if its charging it fully? older trucks the battery cables do go bad and fail flow current or ground out like they should.
RoosterTX
Flower Mound, TX
i have a 2005 tahoe, since new i've basically had to replace the battery within 3yrs. Regardless of usage. Around that age, i will inevitably have a "no start" and need to be jumped. After being left in inconvenient spots a time or two, i always just replace the battery within 2yrs, especially if i know i'm about to go on a trip.
EvergreenZ71
Firefighter EMT/First Responder
Washington
That was my experience with Optima yellow tops in the early 2000s. My 02 Tahoe had yellow tops (eventually dual yellow tops) that lasted almost 8 years first round, 4 or 5 on the second round, and just out of warranty the last time before I got the 09.
Manufacturer quality is not the same. IMHO, as the technology improved it allowed the companies to know how to build them to guarantee most last through their warranty, but not significantly exceed it so you’d need another.
And also IMHO, while someone could probably also do a 48 or 60 month battery at a premium price, I’ll bet their research indicated:
1) Not enough people would buy them at the same time-adjusted profit margin, and
2) There’s a higher risk that temperature extremes and short distance driving would cause premature failure and warranty claims.
a1parrothead
