07 Valley cover
crownvic31
2007 escalade 6.2.
I want to go ahead and replace the valley cover and intake gasket while I'm there. I under stand that my 07 escalade has the AFM/DOD installed but not turned on which is great. My question is can I get a smoothed out valley cover with out the solenoids or does it have to be the same as the one on my escalade(waffle) and the solenoids?
Reason is because the gasket for the valley cover is leaking.
donjetman
My 07 6.2L Denali valley cover came from the factory smooth. Yours should be too.
C
crownvic31
Mine is not the smooth. It has the waffle type. See pic below.
This was when i 1st bought the escalade. While searching for an issue, the intake manifold had to be removed.
donjetman
Ok, a few early 2007 6.2s came the DOD/AFM hardware but it was deactivated in the ECM.
Smooth non- DOD/AFM VLOM on amazon etc for $65.
C
crownvic31
@swathdiver and @donjetman
So to better understand this, as of right now, my vlom has the solenoids for the DOD/AFM but its not needed because my escalade came with this feature deactivated?
So replacing with the smooth non DOD/AFM VLOM will remove them solenoids and I will not need to replace anything esle?
That's correct.
Out of curiosity, what's the build date of your Escalade? The AWD Esky's started production in January of 2006 and the RWD versions in August of that year. The cut off for the AFM equipped L92 motors was like April of 2005.
donjetman
C
crownvic31
So to my understanding and reading online I gathered this info and I quote
""1st design" engines built prior to April 1, 2006 had AFM components but were not connected. "2nd Design" didn't have AFM components at all"
C
crownvic31
Excellent.
She is old but holding up pretty good with 124k miles.
So to gather all my parts, i will need the vlom, intake gaskets and what esle should i be getting?
Oil pressure sensor was replaced so we can scratch that.
Excellent.
Valve cover gaskets? Any broken exhaust manifold bolts? Beware of "mission creep"! LOL
C
crownvic31
Valve cover gaskets were replaced with new gm valve covers a few months ago. Broken manifold bolts were replaced when shorty headers were installed a few months ago.
So pretty much just remove intake manifold, clean up everything nicely, replace vlom and install intake and call it done?
Now that I am looking at the pic of my engine, I am seeing a very rusted line that goes from cylinder head to another at the front. What is that? I should replace that aswell.
C
crownvic31
Should I also go ahead and plug the holes in the valley or its not necessary?
This'll do.
I think you're referring to the coolant crossover tube. Since you're working in the area and if it's really rusty, you might wanna change it. I don't have the part number and there are a couple different versions. Just Google "coolant crossover tube AC Delco" and you should find plenty of replacement options. Fel-Pro ES73027 is the gasket kit for it. It will also contain gaskets for the rear block-offs.
Not necessary. Just cheap insurance should the O-ring seals in that valley cover leak. They often do at well above 100K miles. You'll be good to go for a while with the new parts. But, if you wanna spend the extra time and a few bucks, plug 'em. Some companies have specially-machined aluminum plugs for around $40. An A-37 bearing is around $20 locally and $10 on eBay. There are plug "kits" on eBay consisting of eight of the rollers from an A-37 bearing priced around $20-$25. If you have the means, you can buy a bearing and cut it to remove the rollers and you'll have 20 "plugs".
C
crownvic31
So I am looking at the GM GENUINE 12598832 VLOM. have read bad reviews on the oem unit having very poor casting quality which reminds me of the valve covers when I bought them OEM as well. What are you guys using as per the VLOM goes?
