Really enjoying this new Denali XL
kbuskill
NE. FL.
So I think the air compressor is dead. Fairly common. Arnott shocks # 2708 are about $ 200 a piece rebuilt including a core of 50.
Where is the compressor so I can check it.
Drivers rear outside frame rail behind the rear tire.
looks like from I have read the gds2 won't work on the camaro either, if you are planing on doing your own repairs and troubleshooting on the denali I would just grab a tech2 off of ebay it will pay for it's self in due time. They run about $300-350, no subscription required unless you plan on programming a module or something in which case it's $40 for 2yrs per vin number which is not bad at all considering what the dealer will charge for just about anything.
avalonandl
avalonandl
Troy, MICH & Naples, FL
Taking Denali into Savoie in Troy to get plugs and wires on 8/14. Then heading north on 8/15.
Tech 2 is packed as is the Arnott compressor and tools....
St. Louis
@avalonandl
Are you able to adjust the brightness and contrast on the backup camera view?
I'm told, and it says in the manual, that while in reverse you should be able to push the menu button and have those adjustment settings available. I can't get mine to do that?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
avalonandl
avalonandl
Changed the Air Compressor ad put in the new fuse. What an absolute Bi$ch it was. I had to cut the connector (discontd the batt first) to get the wire harness apart. It was CAKED with dried mud.
see pic of compressor- fully trashed
wjburken
Eastern Iowa
Yep, that’s about what I would expect. The two that I had to swap out looked very similar. After the first one, I learned to put a grinding face mask and stocking cap on to keep from looking like something exploded in my face.
avalonandl
avalonandl
Annoying rattle when on dirt roads. I think its the door lock on the RR door. It seems to be loose and rattle against the escutcheon. I need to confirm thats it. My fix would be to put some 'noise tape" on the button. This is the stuff that is like tape with a light fuzz on one side. Its used between plastic parts to reduce interior noise. I'm up north so not near my supply (used to work for OEM interior supplier).
Anyone else have this issue?
St. Louis
I did on my 2011. I bought a pack of velcro ovals from walmart (in the craft section) and took the fuzzy sides and cut them in half. Removed the lock knob pulls and stuck the fuzzy velcro to the door panel behind where the pulls go then reinstalled the pulls.
I think that light fuzz rattle tape is called Flocking tape?
avalonandl
avalonandl
That’s a funny word!! Sorry that’s how my 12 year old brain works haha. I need to get me some of that. My door panels on my 2006 rattle a tiny bit and it drives me bonkers!
The rattle is only bad on dirt/washboard roads and then it rattles like crazy. Stereo will not drown it out except at nosebleed levels.
avalonandl
avalonandl
Well driving 244 miles from northern michigan to Troy, headwinds brought my mpg down to 17.3
Until I hit the traffic jam for an overturned scrap metal truck in the ditch. Then it wen to 16 sumthin waiting 20 minutes to get by.....
petethepug
Michael
SoCal
Our 08 Denali XL just started doing this in the exact same place lol. Going to buy some of the self adhesive velcro tape and use the fuzzy side.
Z55 option is Auto Ride. Computer controled Magnetic Ride Control / MRC / MagneRide struts on all four corners with rear having a pair of integrated air shocks to level the suspension.
Annoying rattle when on dirt roads. I think its the door lock on the RR door...
The MRC isn’t something to balk at and yank out. It’s oem on:
Ford Mustang Shelby GT350 (2015- model year)
Ferrari 599
Ferrari F12berlinetta
Ferrari California
Ferrari FF
Ferrari 458 Italia
La Ferrari
Lamborghini Aventador
Audi TT
Audi S3
Audi R8
Acura MDX
Acura ZDX
Land Rover Range Rover Evoque
Land Rover Discovery Sport
dizhai
