Front Struts non-Magneride type
tmurray4192
Vehicle:
* 2017 Yukon XL SLT 4x4 5.3l Flex
* Front Struts: (non-Magneride type) coil over shock
* Rear shocks: ACDelco air shock with auto leveling
* Tires AT type
My Front struts are leaking and causing some chop to my tire tread. Time to replace. Handling with original struts seemed fine. I do tow a 6000 lbs. boat so any replacement that would handle that is a must. I found KYB at AutoZone website in which they had two different models ASR4546 and ASR4546K. AutoZone and KYB Websites didn't compare them. Any clue what the difference is? The ASR4546K were more expensive. Not looking to raise SUV height above manufacture original height. However, if a better ride comes with a bit higher stance, so be it. Any suggestions or comments welcomed.
KYB Truck-Plus Front Leveling Assembly ASR4546K
jets
I have Belltech sp all around and they’re awesome.
Thrust
ICT
The K comes with a spacer to install at the lower A-arm. That's why they are "leveling", otherwise they are the same as the non K part number.
B-train
I'd stick with OEM personally. Been down the aftermarket strut road before and they just don't seem to hold up like OEM ones do.
I've also had good luck with car-part.com for low mile salvage items. I put 2019 tahoe struts in my 2008 Yukon for $350 delivered - rust free crashed truck with 19k. Just ideas
jets
Hey if you can find them cheap awesome. I had to replace all four corners and was quoted close to $8K CAD at two places. I decided to drop it a bit and did BT all around and magdelete for less than half the cost. I’m happy.
tmurray4192
tmurray4192
First thank you for the response. I am a typically an OEM person as well. However, this 2017 Yukon OEM parts seem to be failing a lot sooner than my other older (2005, 2009, 2014)GMC/Chevy full size SUV's did. after 80,000 miles with seasonal towing I have had to fully rebuild tranny (known running too hot issue) and replace ac condenser (known OEM leak), rear air shocks (known to leak), front struts (known to leak), and I believe the radiator soon. Point being I am gun shy in using OEM anymore. "Rant"... It seems as if they are engineered to fail sooner so you spend more money more often which means you bring it to the dealer. Nope! I will fix it myself, you won't get my money in your service center. "End Rant"... I will try the KYB and see what happens. I know what OEM does, at least for this vehicle.
K2 Kaiju
The Depths
Its always a moving target. Many new OEM parts have different numbers because they are improved versions of the old design. I have the magnaride, and the replacement AC Delco struts now have a Lifetime Warranty - Arnotts are down to 2 and cost as much. GM really shines after a refresh, but really sucks after a full redesign...
tmurray4192
tmurray4192
Thanks again for response. I did put the KYB's on and what a difference. Not that AC Delco wouldn't of help (I have AC Delco air shocks on the back, just replaced). The unbearable hum of my AT tires at 50 to 60 mph is now gone! I did find some tire cupping on the front tires after the fact. The KYB came with a 1.5 or 2.0 inch spacer. I didn't install it. I wasn't sure how this would impact body leveling sensors. The front end is at 36" and the rear is at 37". This is after the suv is started and the rear air pump turns off. I assume the spacer would make the front and rear 37" (from road to middle of bottom side of the fender, just above the tire). I figure I would research and install if recommended.
keithcruiser
Hi B-train, I have a 2018 Yukon XL Denali with Magneride and the right front shock is leaking at 78,000 km (49,000 miles) and that doesn’t give me much confidence in OEM. Am I just unlucky? It rides like a bouncy castle now!
B-train
The newer ones don't seem as robust as the 2007 to 2014 unfortunately, but failure at 49k is pretty crappy. In my experience, there isn't an aftermarket solution that rides as well as OEM, and cost wise it's a not much more
JPeter
