Geoffsfas10
St. Louis
Speaking of fluid changes... those who have changed trans fluid, is it really as much of a pain in the ass as it seems or is it more just a mess? Id like to do it before roadtripping it a good 2k or so
j91z28d1
when I did my first change after getting it at 135k. my t case magnet scared me lol. fluid was black water. rear end had more metal than I've seen on a magnetic before and I've taken apart rear ends that whine so bad you hear them 2 cars away haha.
I'm surprised the t case works, not that I need 4wd for anything and the rear is quiet. the regen does put a lot of load on the coast side of the gear than normal. some extra wear could be from that.
j91z28d1
sounds like it depends on the tranny. some you gotta pull the exhaust to get the pan down it seems.
mine was simple, drop pan, change 2 filters fill with 12qt. but I have a 2ML70. it's odd lol
With the way you drive, it'd be a surprise to NOT find anything! :p
When I did the front diff I expected to find metal for sure but it still looked like brand new oil I was very surprised. I anticipate finding some silt at least, when I put the girdle on it there was very little of anything a couple years ago so that was about 25-30k ago
Charlie207
LFOD, New Hampshire
If you have a buddy with a long prybar, it's easy to drop the pan on the 6L80; no need to undo any exhaust stuff.
*hopes for more surprises*
mikez71
installed what is hopefully the 220amp alternator. (13536552) The wire plug and alternator cable are in slightly different spots. Alt cable was on back, now on top. Slightly larger stud, old eyelet fits perfectly though. The new wire plug has 6 slots when the old one had 4, but they line up and it snaps in like it should.
left new (20k miles), right old (200k?)
had to notch bottom of cable boot to get it up over the stud. Will hopefully get the right boot when i upgrade the cable..
engine cover sits down, just had it up for photo. only hiccup was easing one mounting bushing forward so I could slide alternator in, found the parts to make a puller..
Thanks Doubelieve for the 220amp tip! And.. thanks to the BEST forum!
Thekenstar
