Metal in oil
87carl
Went to change oil few minutes ago and found this on the drain plug alot of flake and a couple big chunks. She has been throwing p0016 cam crank code for couple of weeks. Could all this be just from a bad timing chain? Do I need to rebuild the engine or will it be fine if I just put a new timing chain on?
IMG_20210410_174805896.jpg IMG_20210410_174819310.jpg IMG_20210410_175309864.jpg
87carl
87carl
The oil change was overdue have not done it since last summer. My odometer don't light up (gauge cluster has something wrong with it) so I do not know exact miles on oil but probably round 7-9 thousand miles. Has good oil pressure round 40-60 psi normally no nocks or noises engine runs very good.
Bill 1960
Testing the Limits
Are you getting any unusual engine noises? I have not spent enough time on the inside of a 5.3 to give any specific advice. In general I’m thinking the source of that is making some unhappy noises.
Missed your second post while thinking... asked and answered.
Well something is not right, I would start with having a look behind the front cover and drop the oil pan to see what else is in there and take it from there.
87carl
87carl
Ordered parts for timing will pickup in am. Anyone have any good how too vids or write ups never done this on a ls engine before and is there any specialty tools I'll need? Got the belt and water pump off so far. What can be done bout crank relearn I don't have a scan tool. hopefully I don't find anything to bad in there.
Foggy
KS
Your crank sensor is a magnet.. So the metal is all over it too..
Make sure to replace it for sure.. It will quit working covered in metal.
87carl
87carl
Could that be the cause of the p0016
87carl
87carl
When I get pan and front cover off tomorrow is there anywhere specific I should look for sources of the metal? What could lose that much metal without making noises or causing problems?
meandmyhoe20
