Changed the oil again. Didn't bother with filter as it was only changed a couple weeks ago. I was going to do transfer case also but the Wally World container doesn't fit my fluid pump. Washed out an empty coolant container so I can use that and will do it later in the week.
I've had a noisy lifter for years, back end of the passenger side. It got so noisy sometimes I was worried it was damaging the engine. I did a few quick oil changes with Wally World cheap synthetic and 1/3 can Seafoam last year and it has been much better. Oil was coming out black after a couple hundred miles. For too many years I was changing the oil every 3k, but that was taking me 1.5 - 2 years to hit. Realized my mistake and now try to change it every 6 months or so.
Recently the oil had been in for a year /1500 miles and I heard an awful racket a couple times from the top front / mid passenger side of the engine. I stuck 1/3 can seafoam in and changed the oil a few days later and I haven't heard that again. Lifter is still showing up quietly once in a while.
I had cooling issues a few years back and the engine got a bit hot a few times before I took care of it. Probably didn't help. That's been part of my reasoning for excessive oil changes.
Now I'm wondering if the high engine temp from the dodgy thermostat i swapped has been making the oil deteriorate faster. That's the main reason I changed the oil so quick, it was in for a couple weeks with the bad stat. I guess I'll find out from how it looks on the next oil change.
Happy wrenching.
