96-2D-Hoe
- Joined
- Feb 14, 2019
- Posts
- 529
- Reaction score
- 409
Yes. The ground for the crankshaft sensor is also on the stud. Need to disconnect the crank sensor connector and move the wire as it's in the wayThis is the one by the crank sensor and balancer?
It's basically the main ground off the battery. I've cleaned up most of the others but until I did this one it hadn't made much difference as the others were 'downstream'.
Battery terminal > Front engine block
Rear engine block > Frame
Frame > Firewall
is the flow and all the main grounds that I'm aware of. There are probably a couple more
