Motor oil revelations !
thompsoj22
not much has changed since 1968 on the v8 engines only minor modifications to improve emissions and mpg slightly..
the only big changes were to the intake, ignition system and injection system.. it's still the same ole cast iron engine under that plastic cover..
the major change was on the Gen 4(inbetweener) when aluminum block, VVT was added & high pressure variable oil pump* hybrid model only..
those are just revisions and after thoughts..... it's only been 5 gen changes since then, those are considered "major changes"
you know fuel injected has been around for a while since 1957
Hey Brent, I gotta ask and being completely serious. Have you ever removed, torn down, Outsourced machining and "completely " Reassembled an engine or transmission and reinstalled it yourself? Be honest!
...it's still the same ole cast iron engine under that plastic cover..
and they are different gens, that explains why they're completely different. no duh.. each gen is just a redesign .. duh
So, it's the same cast iron engine, but it's completely different, but it's just a redesign?
...Are you a politician?
BG1988
the only reason why it was even bothered to do any updates was to meet tighter emission requirements
other wise there would be no innovation..
it's one of the reason why the 5.7L was gone in 2005. No way to improve the emissions output
you got your information from wiki correct
swat2380
How do you have the time to bless us with your knowledge with all that dirty oil needing changed?? :) You are obviously an expert and cannot be taught but that's cool I will just go back to playing with my own toys. I should probably get off this forum and check the ole heap for clogged pushrods. BTW my boat is just as badass and I actually learn something everyday from people smarter than me. You should try the same
The Gen3 small block is 100% newly innovated and an improvement in pretty much any aspect possible over the Gen2 and older. It's more efficient, stronger and more easily serviceable. The only thing it shares with the previous generation is cylinder spacing and the bellhousing bolt pattern. You could argue that they share the layout with cam-in-block, pushrods and overhead valves, 2 valves per cylinder, etc. if you wanted to grasp at straws.
I got my information from the engines I've had my hands on and in.
Dantheman1540
Sugar Loaf Mountain
But a 5.7l is a 5.7l so the Toilet bowl injected 350 in a 91 k1500 is the same as the 5.7 LS1 in the C5Corvette. :crazy:
EXACTLY! Just like GM's 2.2L I-4 is the exact same as Chrysler's 2.2L I-4. And Ford had a 2.3L "Iron Duke"...
I don't intend to make this a pissing match with Brent. But I can't quietly stand aside while someone slanders the LS! lol
Dantheman1540
Sugar Loaf Mountain
I'm just teasing too! Heck this place is all about knowledge and fun right!? :chewie:
Black Limited
i'm 4500 miles into my oil change the oil is still clean :) the issue starts from the first owner some will change it every 7.5 or 10k miles that is if you only want the engine not to last very long...
I change as soon as i see carbon flakes floating in it.... honestly i;m a bit surprised its still clean.. but normally there will be some carbon flakes floating around at 4500 miles.... the engine mostly runs between 1000 and 2000 rpm Never driven higher then that RPM..
go get a Genuine corvette oil pump shell run 40-50PSI idle and 70-75PSI on a cold start :D
What are carbon flakes...………..and what do they look like......……..news to me !
Black Limited
scottd
