Motor oil revelations !
swat2380
what it's true the tiny push rods that carry oil to the top of the engine will get clogged over time there is this one guy with his 5.7L and it takes 45 seconds for oil to reach the top of the engine those tiny tubes get clogged easy
skip the video to 6:50
you will get the point that dirty oil does not pay to keep in the engine
No I still don't get your point because I am fairly educated what I'm talking about. If you like your way I say go for it but please don't offer any advice to others on this subject
wjburken
Eastern Iowa
Please keep in mind that Brent drives a Hybrid. He fails to mention that little tidbit when talking about fuel economy and what rpm his motor runs at. Hang around and you will hear about the other magical aspects of his vehicle.
BG1988
1,030RPM @ 40MPH what ever oil changes too far inbetween is the failure of your AFM.
so your advice is that it's normal for no oil to come out (or dribble out of the rods)? oil should be going everywhere..
like this
Bob2C
Northern VA
Got my oil report back using Rotella Gas truck. Copper high for 3k mile change.
thompsoj22
like this
Hey brent, i made that video in 1968 on my 283 chevy SB. come on man apples/orange's. You are entertaining though so what the heck!
BG1988
not much has changed since 1968 on the v8 engines only minor modifications to improve emissions and mpg slightly..
the only big changes were to the intake, ignition system and injection system.. it's still the same ole cast iron engine under that plastic cover..
the major change was on the Gen 4(inbetweener) when aluminum block, VVT was added & high pressure variable oil pump* hybrid model only..
Yeah? No changes to the oiling system? The bottom end is still the same 2- or 4-bolt mains? Same bores and strokes? Same rod and cap design? Same skirt depth? Same weight?
BG1988
those are just revisions and after thoughts..... it's only been 5 gen changes since then, those are considered "major changes"
you know fuel injected has been around for a while since 1957
BG1988
those are sub revisions with in a generation.. Rev: LS2 ,L98,L76,LY6 etc..
Brent, that's just not so anymore. About the only thing the LS has in common with the SBC is bore spacing, the oiling system is entirely different for starters.
avalonandl
Troy, MICH & Naples, FL
Annnd we're off and running.........
The only common parts on a 283/327 SBC and a LS engine are.... well there aren't any......
The block, oiling, cylinder heads, etc. are completely different.
BG1988
and they are different gens, that explains why they're completely different. no duh.. each gen is just a redesign .. duh
avalonandl
No, its a COMPLETELY new design ground up, clean sheet of paper etc. The LS and old SBC are completely different engines.
The difference in LS engines, may be generational until you get to the Direct Injection engines.
PG01
Up here to the right
Are you really gonna put the wear and tear on your keypad/keyboard to fix him?
Lmao
schafer98
