Motor oil revelations !
Black Limited
i'm 4500 miles into my oil change the oil is still clean :) the issue starts from the first owner some will change it every 7.5 or 10k miles that is if you only want the engine not to last very long...
I change as soon as i see carbon flakes floating in it.... honestly i;m a bit surprised its still clean.. but normally there will be some carbon flakes floating around at 4500 miles.... the engine mostly runs between 1000 and 2000 rpm Never driven higher then that RPM..
go get a Genuine corvette oil pump shell run 40-50PSI idle and 70-75PSI on a cold start :D
What are carbon flakes...………..and what do they look like......……..news to me !
Black Limited
