Official 00-06 Tahoe/Yukon/Escalade drop guide with pics...
1lowhoe04
Fort Worth Texas
Mines 4/6 with arms up front I have the spohn arms for rear but don’t understand how much to adjust
Bombsquad85
Northern VA
So on the ride from Boston to DC my wife and I were taking about the ride.
Over alm the beltech silver shocks are good however on hard bumps the truck feels like I hit a wall. Will 4600s smooth out those bigger bumps or is that a 22" wheel with 285/45 problem?
Has anyone gone from beltechs to 4600s? If so is there a noticeable difference?
Drewskiiiiiiiii
I have an 03 tahoe with the djm TB 4 in springs in the rear and it’s at 34in ground to fender. Am I missing something here?
ThwopKing
Bunker Hill, WV
Model/Year/2x/4x/AWD:
- 2003 Tahoe LT 4x
Advertised drop:
- 2"/4"
Fender height front/rear:
-32.25/33.50
Front:
- LCA's : stock
- UCA's : stock
- T-bar keys : 2/3" McGaughy's keys
Rear:
- Springs : Crown 4" springs
- DJM shocks extenders
Wheels & Tires:
- Wheels : 20x9 oem tahoe ltz
- Tires : Goodyear Eagle LS-2 275/55/20
- Autoride disabled
Considered upgrades: spindles
Brief impressions of setup:
Feeling bumps more than before. Stocks need to be replaced tho. More sway and roll, but not in a "dangerous" manner. Suspension has settled, hate to do it but need to raise font one inch to match the rear ar 33.5"View attachment 208267 View attachment 208268 View attachment 208266 View attachment 208269
Any rubbing issues with those 275/55's at your current drop?
05Single
afraid of the dark
No and yes. Everything clears, but sharp right turns combined with bumps-dips my drivers side rear tire hits the wheel well liner. But that's because theres a bulge for the autoride compressor. So a typical non autoride tahoe would not hit. I need to find out the offset on these ltz wheels, might get 1/2" or 1" spacers.
ThwopKing
Bunker Hill, WV
Ok cool thanks im liking your original setup.... not too high... not too low and i kinda wanna run that tire size because i can still get all terrain tires i still wanna run.
Sent from my SM-G960U using Tapatalk
05Single
afraid of the dark
Yea it's perfect for fitting a factory size tire. Still have a ton of sidewall for ride comfort.
ThwopKing
Bunker Hill, WV
I actually wonder if it will be enough drop now..... the truck im picking up was a government issue truck and basically has Z71 suspension. I'll take some measurements when I get it home.
05Single
afraid of the dark
Should be same exact measurements after drop.
ThwopKing
Bunker Hill, WV
After picking it up not sure if I wanna try a basic rear drop to level it out first or go for the full mild drop all around lol
BADRIDES
I've got a rear set of belltech springs for sale if you want to level it out.
1bdhoe23
Belltech drop shocks on the front, dim spindles, 3" keys, rear air shocks and helper bags(drag race often so it launches very hard with them adjusted) modded sway bar links front and rear, custom spring rate 5.5" rear springs, notched frame, belltech bumps, Spohn Panhard, Spohn uca and lca. I sit 30" in the front and 31 in the rear.
Drewphil
