Wireless charging module update, GM part number 84526978 (plug/play harness)
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Yeah but no CarPlay without the cable right?
I can stream any music source from my iPhone, and have hands free calls. The only thing I can’t do is display my iPhone screen apps on Tahoe screen wirelessly. I’m ok with that. Probably would be “air play” if I could. Map software is already on my radio. Just not Waze.
cardude2000
Can you search through artists, albums, podcast etc on your phone via the Tahoe screen? I figured you could only do that via CarPlay screens.
Either way waze alone is worth it to me to plug in my phone.
But to each their own. Glad you got wireless charging to work. Just seems like a lot of work to eliminate a small cable and lose CarPlay altogether.
RST Dana
OH
Yes I can browse music on my device, and my mod took less than 10 minutes. WAZE can be hit or miss, that’s why I run an ****** Redline Ex, with Waze running on a separate device on long trips
cardude2000
No I mean browse on the Tahoe screen.
RST Dana
OH
I mean browse on the Tahoe screen to my music saved on my iPhone. By Bluetooth I can browse by song, artist, etc. Believe me, it can be done
cardude2000
Ah ok cool. Does it have to be saved on the phone or can you access music in the cloud (Spotify, Apple Music etc)?
RST Dana
OH
No clue about those. I don’t spend my coins on it since I have XM for less than $3.00 per month for the next 4 years anyway
cardude2000
Yeah me too.
Sometimes like to listen to what I want when I want though.
Either way thanks for the info. Try out CarPlay sometime. It’s pretty slick.
Tiki
This is what I ordered and installed. I wonder if it was boxed wrong?
That looks like the older module. The new module I got was black. If it were me, I'd re-order through TASCA. I've bought through them several times and while they can sometimes be very slow, I've never had a product issues.
calif phil
Concordia KS
I wish I had a picture of the module that you guys used, to show my GM parts guy and compare to the one they sold me. I am going to check for power and ground and if that is present I will ask for another module. He said he thinks the dealer had a wireless charging tester but nobody knew where it was.
Bob2C
Northern VA
This is what I have and it works fine with my iPhone XS with the case on. Maybe you have a defective unit. Yours looks the same as mine
Tiki
There are probably a few different versions by now
calif phil
Concordia KS
It looks like I do not have 12v to the #1 terminal of the connector. Which is the Violet/yellow. Anyone know what fuse supplies the power. I checked the 2 dash fuse boxes and the one underhood and none that I could tell were blown.
calif phil
Concordia KS
Success! Dealer could not tell me what fuse powered the wireless charger other than it was with the RAP. Since my retained acc power functions I looked further and found three broken wires around the console door hinge.
I fixed the wires, installed the new module and it WORKS.
Rdr854
Northern VA
How did you get XM for less than $3.00 per month fir the next 4 years? I was only offered 12 months for $4.99 per month.
Denali Brad
Considering doing this on my 16 Denali, did anyone change or rotate the mat, or simply plug/play from the underside?
Brad
Bob2C
Northern VA
Brad
I added it to my lt tahoe that didn’t have wireless charging. Just tapped into 12v power source at lighter behind console. I bought the rubber charging mat as well. Mine works the right way without reversing. iPhone 11pro
joe_joe
What all is needed to convert my 2015 Suburban console to a wireless charging console?
What modules, harnesses etc are needed?
Thanks guys/gals.
JasonW4141
