Wet Concrete From Transmission Extension Housing
YukonCrazy
Raleigh, NC
My RWD 2008 Yukon has been sitting in the driveway for a couple weeks now because of the work at home thing. I haven't used it at all in that time and yesterday I noticed a big wet area under the vehicle.
The driveway has a slight incline so the front end of is slightly raised while parked. Looks to be a slow drip from the transmission extension housing. I actually replace the transmission extension housing about 2 years ago, which came with a new seal already pressed, so I find it odd it's leaking.
I am going to assume this behavior is not normal?
Maybe just replace it with a new one because maybe the one I got was bad? Suggestions?
Is there an online parts catalog where I can confirm the part number?
Thanks.
A big wet area under the truck should not be considered normal, IMO.
Folks here will chime in with their thoughts and perspectives.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Pics of the "big" area would help. May have a yoke problem as well so check for that when you slide it out. Sounds like the incline and the long sit contributed to this since you never noticed a leak before. You can just top off fluid and drive it and keep watch to see what happens. Can you park on a level surface anywhere close?
YukonCrazy
YukonCrazy
Raleigh, NC
Before replacing the slip yoke and transmission extension housing, I was dealing with the "GM Clink". Replacing those fixed that problem, but may have introduced this problem in addition to the continual slight vibration I have had since then.
PG01
Up here to the right
If you think the slight vibration is connected, since you said it started after replacement of housing, i would check the driveshaft and have it balanced. It may be enough vibration to kill that new seal in the new housing.
YukonCrazy
YukonCrazy
Raleigh, NC
As part of my 2 year long diagnosis, I bought a brand new driveshaft, which had no affect on the vibration. The other two items are slip yoke and transmission extension housing.
YukonCrazy
YukonCrazy
Raleigh, NC
About the same time two years ago, I had one of the mounts was replace. Damn, I can't recall which side, but I do remember the way for checking it, putting it in gear, foot on the brake, hit the gas, and one side of the engine clearly comes up a few inches. At any rate, it was just one side that was replaced.
thompsoj22
california native "REPUBLICAN" high desert
the thread title is 'wet concrete, am i to assume it is a "grey muck" as opposed to an oil leak? you dont drive it through those bullshite auto washes that blast the under carriage with water do you? it is a longshot but liquid grey concrete is not oil its corrosion? and the vibration that started with the slip yoke replacement is likely the yoke/ujoint out of alignment. if you can feel the vibration in the vehicle somthing is getting the crap whooped out of it everytime you maintaine that rpm or "frequency" i balance helocopter main/tail rotors for a living. vibration destroys components.not to freak you out or anything:eek:
I see water under mine some mornings as the dew is burning off, water is running down off the truck, around doors, sunroof drains, rear hatch, etc. No internal leaks, just water finding its way to ground.
Now if the wet area is red, that's another set of circumstances! Either a cat ate a rabbit under your truck or your transmission might be a leakin'!
Yea, he said a small drip from the transmission tail housing. I ASSUMED red fluid.
Nobody thought it strange he said “wet concrete”? To me that means water or coolant. Although I guess transmission fluid is wet , when I see it on concrete I don’t say the concrete is wet. I say there’s trans fluid on the concrete. So what is it @YukonCrazy ? Trans fluid? Water? Dexcool? Oil? This is killin me lol.
wjburken
Eastern Iowa
thompsoj22
ok, now i get it. The concrete is wet and it must be trans fluid. i took it literally.:laughing1:
wwiizz
