6.2 swap thread
L
ls1frc
Well, got everything installed.
Turned the key and heard immediate screeching. I tried a couple times and it backfired. It did make great oil pressure.
I have a feeling I somehow still screwed up the cam phaser install and that is the screeching noise. I really hope so, because I will just run my 3 bolt cam if that's the case. I will start tearing down the front cover and valvetrain now, will report back.
L
ls1frc
I didn't have any coolant in the system, could the water pump make a screeching noise if it's dry? If I can get an answer on that, I'll try running it again with no belts.
PatDTN
Ooh. Hope it's just the coolant issue. After all of my install I have a bad bearing in my water pump. Replaced the idler pulley then swapped the tensioner pulley off my 5.3 and still have the noise. >sigh<
Congratulations! I can't believe how calm you were throughout the whole process. I would've been cursing from sun up to sun down lol! Glad you got it going. I have a similar melling oil pump in my van, warmed up idling the oil pressure is like 60 psi. I agree with you on should've went down a step or just swapped out the spring.
L
ls1frc
Thank you. Im pretty stubbornly persistent. This time it paid off. I had to get this thing running, today was the last chance before frozen hell.
As the oil warmed up, the melling calmed down. Its now about 32 at 525 idle. Ill roll with it.
Looking back, the one part of the job that made me curse was simply separating the trans. That was tough.
L
ls1frc
Anyone have ideas on how to quickly sell my 5.3? Not sure what they go for.
L
ls1frc
I also have lightly used PRC 2.5 243 heads with PAC 1219 springs. And the stock intake manifold.
L
ls1frc
Lol it's literally 10 days straight of precipitation. Won't get any WOT tuning done for a while. After how it felt at part throttle, Im dying to see what WOT is now.
PatDTN
Your new torque converter might complicate snow starts.
brice715
