dkad260
Totally normal. I have taken the rear mount loose and jacked the trans up enough to wiggle it out. Some can just wiggle out.
I tried that....the exhaust rotated up with the trans. I could get a small amount of added clearance but not enough.
SpareParts
North Idaho
Gave it a bath! Just ran it through the touchless car wash.
Scrappycrow
Air Force
Alpharetta, Georgia
The standard advice (and which is what I resorted to for my first and so far only trans filter change) is using a big pry bar to force the exhaust down to the point where you can edge the pan out. TBH, it's frustrating and messy, so I will likely undo the exhaust next time.
Dirty looks
Played around test fitting on the ultimate adventure vehicle. RPD rack and propane carrier. Overland Vehicle Systems trash bag, Open Road shower and water heater.
Waiting on the 270 awning plus.
JoeBlobs
Senior Member
NJ
Got a Tech2 question if anyone knows off the top...
I have some missing DIC options, is this something I can activate simply with the Tech2 or do I need to do some programming? Do I need AcDelco TDS/SPS2?
has to have the eeprom programmed with a special interface. I have never built one but I am sure all the how-to's are online
JoeBlobs
Senior Member
NJ
Tech 2 won't do it. What options are you missing?
Perimeter lighting options.
Seems like fun but more time and money than its worth for making the puddle lights work. Hard wire it is. Thanks though bud!
Dirty looks
When I did it I wedged a long prybar in there and used a floor jack to force the pipe out of the way. The flex coupler was a flexing...
Dirty looks
Finished the last 10% of the bumper build. Got the little extra steel parts welded and painted, the light bar mounted and wired, and even managed to reuse most of the hard foam insert behind the bumper cover.
I imagine it helps funnel air into the radiator and other coolers by blocking off the air flowing down.
I have to figure out a good foglight solution. Square lights on L-brackets would be the easiest to cut and weld for, but I like the idea of somehow reusing the factory lights. It would be significantly harder for me to cut a bice oblong hole and use the OEM light mounts.
Time for a barley-pop.
Looks beefy..
SpareParts
North Idaho
No clue. They were on it when I bought it. I like em so i decided to keep em.They do say GMC though.
S33k3r
Dallas, Texas
Getting it done but man im telling ya after 6 months of not doing a lot because of weather doing this work will make you sore all over but at 64 1/2 i can still get it done.
Got the plug's i needed this morning. Free.
Almost done with phase 1.
Need to remove a finder liner to tighten an upper shock mount bolt i found loose.
Temp wire up the front actuator so it has 12V when the key is on and use a 15A fuse so it will drive.
Go for a short drive to see how it drives so i can compare it to later when i tune the trans for 4.10 gr.
I actually don't know much about tuning but i can tune basic stuff using Blue Cat.
Hopefully in the next few weeks i can get a couple of days of decent weather to get the TC changed.
It's so weird hearing everyone's ages. No one acts old, so it's just a little jarring. Note I am referencing age and not maturity. I am 56... My maturity is at least double digits... ;)
S33k3r
Dallas, Texas
4.10 with awd might not be too bad but if 2wd I'll just end up chirping the tires at every stop light or corner unless I'm careful
I probably need to get my tune updated on my truck. If I get on it, it chirps the tires between 50-55mph -- unless I'm in 4wheel high.
BadDaddy2003
