mikez71
- Joined
- Mar 9, 2023
- Posts
- 3,367
- Reaction score
- 4,166
OEM's are definitely going to charge a subscription fee for that option...
need to do my bottom cover also, the foam seems ok but I have a new one anyway did you pull the seat out or do it with the seat still in.
Been hearing some squeaks & creeks from the front suspension.
So hit the zerk fittings on ball joints in my Mevotech TTX control arms with some red & tacky.
View attachment 483744View attachment 483745
Did both driver & passenger sides upper and lower ball joints.
Some squeezed out of my upper driver side which I wasn’t a huge fan of, but I’ll keep an eye on it.
Morning commute into work over my routine route that causes the squeaks will confirm if this did the trick.
It's probably the swaybar bushings that creak/squeak.
Also, you don't need to pump so much grease into the ball joints that it blows out. One squirt is enough to supplant the grease that's cycled through the ball/socket as it cycles through its range of motion.
I doubt you hurt the rubber, as they looked fairly serviceable. I've definitely blown out old rubber balljoint boots after they've been weakened and cracked, and just gave the grease-gun the 21-pump salute. Not wise, but now I know.The creaks & squeaks are gone from the front suspension so I feel like the ball joints were the culprit.
Thanks @Charlie207 Admittedly I wasn't too sure on how much grease to put into them and probably did over do it. I kept slowly adding more pumps until I could visually see the boot expand some. That may have not been the correct "visual indicator" to go by...
Pulled it out. I could not imagine doing it installed.
when you found the drivers side firewall/body leak on yours what did you use to seal it? I assume that was you anyway I could be wrongI've done it a few times both ways. IMHO pulling it out is easier. It's hard as hell to get the bottom cover clips pulled down onto the seat frame, especially along the console tunnel side.
I am one of us here dealing with that, it isn't found/fixed yet. Check this thread out, @Rocket Man seemed to have fixed his:when you found the drivers side firewall/body leak on yours what did you use to seal it? I assume that was you anyway I could be wrong
I guess I am going to grab this stuff and see what I can doI am one of us here dealing with that, it isn't found/fixed yet. Check this thread out, @Rocket Man seemed to have fixed his:
Rocket Man’s 2008 Tahoe Build Thread
Damn. I am watching this. I have the same leak. It's a ***** to figure out. If the rubber backed padding wasn’t completely covering the firewall and going behind everything a person could at least see where it’s coming from. I finally was able to get access to the bottom portion. I have a...www.tahoeyukonforum.com
You have a much higher opinion of the factory fog lights than I do. They're only 25W or so, and the pattern isn't great.... I like the idea of somehow reusing the factory lights.
Looking at your radiator, it appears that you need to blow out the fins to improve air flow.Finished the last 10% of the bumper build. Got the little extra steel parts welded and painted, the light bar mounted and wired, and even managed to reuse most of the hard foam insert behind the bumper cover.
I imagine it helps funnel air into the radiator and other coolers by blocking off the air flowing down.
I have to figure out a good foglight solution. Square lights on L-brackets would be the easiest to cut and weld for, but I like the idea of somehow reusing the factory lights. It would be significantly harder for me to cut a bice oblong hole and use the OEM light mounts.
Time for a barley-pop.
