mikez71
- Joined
- Mar 9, 2023
- Posts
- 3,373
- Reaction score
- 4,186
You wanted girl power...
Just needed 2 minutes on the phone. Fixed!
Wait paw paw, when did you ditch the other amazon pos …. I thought u bought the same one i had???Raised my Stereo up today. It was blocking the lights on the climate control upper buttons.
which repair clip did you use? dorman?Wife is out of town on a “Girl’s Weekend” with a group from her college days.
Called me this morning saying she couldn’t shift her Yukon out of park and the shift lever was loose.
Told her it was likely the bushing on the shift cable at the transmission and that she could probably fix it herself since she was 2-1/2 hrs away.
I sent her a YouTube video of how to fix it and mentioned something about “Girl Power” and the group all having Doctorates in Pharmacy should be able to do it.
Guess who got to drive 5 hrs round trip to spend 5 minutes replacing a $10 part while her and the gals were drinking mimosas at a restaurant.
View attachment 469166View attachment 469167
Mine is the one i always talked about and ordered from day one. Check post #37 https://www.tahoeyukonforum.com/threads/adding-a-subwoofer-stereo.154733/page-2Wait paw paw, when did you ditch the other amazon pos …. I thought u bought the same one i had???
Yeah-Dorman. 2 pack for $12.which repair clip did you use? dorman?
Disregard…. Wrong person… im shotMine is the one i always talked about and ordered from day one. Check post #37 https://www.tahoeyukonforum.com/threads/adding-a-subwoofer-stereo.154733/page-2
I bet that was squeeking good!
Any tips on replacing the door hinge?
BTW, you forgot to paint it.![]()
ya there is a side impact sensor inside all 4 doors (in case you get t-b@ned), if the door fell and ripped the harness it could trigger a airbag pop, not sure on the keeper bolt thoughGreat, no special handling of the door while the hinge was removed?
Like did you need to prop it up somehow? Or just hold onto the door?
charm.li mentions disabling the airbag system for some reason. and mentions a keeper bolt on the lower hinge.
When I’ve had to do this, I just used a floor jack under the latch end of the door to provide support.Great, no special handling of the door while the hinge was removed?
I used it in the middle of the door.When I’ve had to do this, I just used a floor jack under the latch end of the door to provide support.
Sorry yes like the other fellas have said. I used a Jack as well and kept pressure on it, no other special handling was needed.Great, no special handling of the door while the hinge was removed?
