Gruven heater core T-connectors
j91z28d1
I know I'm being lazy and this is a old thread. but anyone have the part number for the oem gm white and back T's? all I find is the Dorman stuff.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
There are actually 3 parts. Black is outboard and white is inboard with the 3rd straight black connector plugged onto that. I would do them all because they are all equally prone to failure:
j91z28d1
thank you. that will. make it much easier. I'm guessing you just squeeze the tabs and pull? no tool needed to remove?
it's got 140k on it and a 2011. so yeah it's due for a coolent flush anyways. good time to do it.
thanks again.
Geotrash
Dave
Richmond, VA
thanks again.
Squeeze the tabs and push in on the hose before you pull. I used a pair of pliers to help me squeeze the tabs.
Wear gloves when working in that area, as the firewall insulation is quite aggressive, and your hands will itch like H-e-l-l for the next few days.
Warriorpluto
I just did this on my truck. I ended up using a small saw from my friend to cut off those crappy connectors. Ill go with the gruven maybe next month when i address every hose in the cooling system. But what about the rear? I didnread that the rear heater core has some problem with the line breaking or something.
j91z28d1
I have the plastic replacement ones for the rear. Dorman seems to be the only ones in that size. I got the part number off here. but I haven't got around to replacing them.
another guy had a hard time getting them off and the hose on the other end is a factory crimp fit to metal pipe. doesn't look fun job and I got lazy. I can look up the part number if you need it but they are plastic
rdezs
I did my rear heater hoses, and modified the OEM heater pipes. No more crimp fitting. Also use the Dorman fitting, 3/4 in to 5/8 hose barb
This is where I trimmed the heater pipes above the spare tire
Ilikemtb999
Denver
The straight connector is not needed for trucks with rear heat.
You CANNOT use a Gruven T-connector to replace the Y-connector down by the water pump BUT you can buy the Dorman 626-553 which is a direct replacement made from aluminum. That is what I used.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/113134563530
The only way you can buy it is with hoses. They don't sell it separately, I called Dorman and asked.
I didn't see this info posted but you can get that Y separate now dorman part number 47157!
donjetman
or
New heater hose w/metal y fitting, Dorman# 626-553 or NAPA# 827-5730-1
Candielaine
