Rear Heater Core
rdezs
Radiator hoses, yes. On fuel hoses, it depends. On a low pressure carbureted system, I have used them. Higher pressure fuel injection requires different type of fitting.
Foggy
KS
You can carefully cut it at the crimp, or replace it. Dorman has a 3/4 inch quick connect elbow that goes to 5/8 hose barb. Drop your spare tire and look up. You'll see the two half inch aluminum pipes, the hoses are cripped to the end of those pipes. It's easier to use a small pipe cutter and cut the pipes, then use a half inch compression fitting adapted to a hose barb.
Here's the parts I used, along with 5/8 silicone heater hose.
And then there's the old ones that were all rotted
Here's where I cut the aluminum pipes...
Not very user friendly to get in there and carefully cut the crimp off, which is why I went with relocating the connection for easy access later on. You can see where the original crimps were
Everything's available on Amazon. I used the half inch compression to 8AN male fitting. Then an 8AN female to a 5/8 hose barb. I prefer the oetiker crimp connections, but of course you can use your choice of hose clamps.
Great Post !
I am going to do this at preventative maint on both Yukons.
Do you happen to have a part number for the #8 an x 5/8 hose barb fittings??
The only one I can find is by aeromotive on summit for $38 each ! Gotta be a cheaper alternative
opfor2
Riverside County, CA
where did you buy the 5/8" silicone heater hose?
rdezs
Amazon. You can find everything you need there for the rear heater hose conversion.
Foggy
KS
I could not find the #8 an X 5/8" barb adapter you referenced...
Any help is appreciated (by anybody) to find it
18Burbanator
What year is your truck? I went to do this to my 18, and I don't see how in the world you had enough room to make this mod, unless yours is in a slightly different position than mine. Mine is not currently leaking, so I decided to leave it alone, as I'm afraid I'll cause more of problem if I try to replace it.
rdezs
2014. Remove the inner fender liner from the right rear wheel well to get access to the heater core 90° fittings. Drop the spare tire to access the metal coolant lines.
Not sure about the 2018 model year. I imagine it should be about the same.....
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Do you think removing the rear bumper gives you even more easier access for this?
Mariam26A
Member Recommended
