Gruven heater core T-connectors
kbuskill
NE. FL.
As we all know, the plastic T-connector "quick disconnects" that connect our heater hoses to the heater core in the front and tee off to the rear heater core are prone to getting brittle and cracking and leaking or just breaking off all together (both have happened to me) and dumping all the engine coolant at once.
I mentioned in a thread the other day that Gruven should build these out of metal as they do there brass mirror gears for our trucks...
http://www.gruvenparts.com/gruvenpa...-2007-2014-gm-trucks-folding-mirror-assembly/
These are great replacement parts BTW.
Well I sent Gruven an email the other day and suggested it to them and after exchanging a few emails, and me agreeing to do a little leg work, they have decided to produce them for us out of Billet aluminum.
I am not certain when they will be available as of yet because they still have to build the prototypes and send them to me for testing but I doubt it will take very long from the sounds of it.
I am hoping that it will be a similar "quick disconnect" type of fitting but that is yet to be determined. It may end up being a barbed type connector which would still be functional but would be a little harder to install due to how the cowl sticks out over top of the connectors at the firewall.
Anyway I just wanted to give you guys a heads up and I will keep you all posted on how it works out.
I will post pics once I have the prototypes in hand.
Well I sent Gruven an email the other day and suggested it to them and after exchanging a few emails, and me agreeing to do a little leg work, they have decided to produce them for us.
I am not certain when they will be available as of yet because they still have to build the prototype and send it to me for testing but I doubt it will take very long from the sounds of it.
That's awesome Ken! Keep us posted, mine are fine but that is the perfect upgrade to ensure 100% reliability in that area.
kbuskill
kbuskill
NE. FL.
He also asked me if I wanted any other mods done to them. I said I hadn't really thought about it.
He suggested cutoff valves so you could stop the coolant flow to the heater cores in case of a leak.
I said that would be a cool feature if you ever needed it... praying I never will... lol
Any way if you guys have any other reasonable suggestions for them let me know and I will pass it along to them and see what they say.
He can't turn this on a lathe, but how about updated navigation discs for our factory nav systems? Cut off valve would be neat but this ain't no muscle car, the heat is on all the time now unlike how they did it in the old days.
What's something weak and breaks all the time? He already does the door handles and gears... Have to think about that.
kbuskill
kbuskill
NE. FL.
He also does door lock actuators.
I don't think he was asking for ideas for other parts as much as ideas to make the T-connectors better.
Although I am certain he wouldn't be opposed to making a completely different part if the need were there.
I think the idea of the cutoff valves was more for shutting off the water to a heater core that was dumping coolant so that you could continue to drive the vehicle until getting it repaired without having to disconnect and bypass it.
For example if you rear heater core developed a leak you could turn off the valves to the rear heater core and still have front heat or vice versa without losing coolant. Or at least that is what I gathered from our brief discussion of it.
kbuskill
kbuskill
NE. FL.
Just got an email from Gruven. He is asking for some input to see what kind of interest there is in these. Here is the content of the email...
Ken,
The only real way we can make this is as machined/tig welded 6061-T651 aluminum Y tube and include 2 short lengths of coolant hoses with hose clamps to allow it to be attached to existing hard lines via coolant hose. Cost likely $69.99 ea lead time 2-3 weeks. We need 10 orders.
Can you post this info with instruction to just email me directly to get on the buy list ?
I will also get some screen shots of the design as well soon.
We need some input/assurance from potential buyers on this. I realize OEM part cost is like $10 so we need to be sure people aren’t just going to buy 7 of the plastic parts and replace them on side of road each time they break. Sounds like a huge pain to me but I know money is always tight so we have to be respectful of what people are willing to pay to end this problem once and for all.
To build the part as per OEM, it would cost hundreds of dollars, and would require injection molding tooling to make the white plastic inserts. Then you would still have a plastic insert in there so it would only be as strong as whatever that was.
Paul
www.GruvenParts.com
https://www.facebook.com/GruvenParts/
So there it is ladies and gentlemen. Please email him directly at...
[email protected]
Also if you do email him please post in here so we can keep a tally of how many we have/need.
kbuskill
kbuskill
NE. FL.
Just a bump for exposure... hoping to get enough interest to bring this to market.
kbuskill
kbuskill
NE. FL.
So here is the latest word from Gruven...
We can do the quick disconnect version but it would be much more expensive. Also, it would rely on the plastic tabs to hold in place, so if those broke then it we would have to make those as well (injection mold, tool cost $5-10K).
We can do whatever people want, but to make metal version identical to OEM would be expensive, like in the $250 each range… unless we could build/design some quick release adapter.
By far the easiest and least expensive way to do this is with a machined/welded tee fitting that utilizes short lengths of hose to connect into the factory lines.
This option would be l $69.99.
Regarding pictures of the design, that would take CAD time. For now you can be assured the part will look similar to the other billet/welded tees we make for the VW/Audi cars, such as these :
http://www.gruvenparts.com/vw-audi-1-8t-golf-jetta-tt-coolant-y-pipe/
http://www.gruvenparts.com/vw-audi-bpy-billet-radiator-hose-4y/
Ken we also ARE looking for more parts ideas, so if any guys on that site/thread have other parts they want considered, please have them just email us directly. We will look at everything.
Paul
www.GruvenParts.com
Here are pics of the parts linked above...
So ours would be similar to these.
I really assumed there would be greater interest for these than what I am seeing in here...:shrug:
kbuskill
kbuskill
NE. FL.
Ttt...
Trying to keep this bumped up for more exposure... if you are interested in these please email them and let them know.
HiHoeSilver
Away!
Chicago
$70 each of for a set? I'm a little confused on how the "little piece of hose" thing is gonna work.
kbuskill
kbuskill
NE. FL.
I guess it's $70 each but I will ask for clarification.
It would just be a piece of hose, maybe 3"-4" in length, slipped onto the heater core nipples and clamped and then slip the new T connector into the other end of the hose and clamped. Same for the lines going to the rear heater core.
It would obviously be a bigger pain to install because of the location being tucked up under the cowl on the firewall. BUT on the bright side it should be a permanent one time fix, never to be fooled with again. Unless the rubber hose deteriorated and needed replacing.
It might be worth going with silicone hose for the short pieces to avoid rubber deterioration.
kbuskill
kbuskill
NE. FL.
So to clarify they would be $70 each.
Trying to stay optimistic but not seeing as much interest as I expected. He has only had 1 email so far.
Ilikemtb999
Denver
I’ll assume that was me then. At $70 each I don’t see this going much further. At $70 a pair I was in.
HiHoeSilver
Away!
Chicago
I'm in a similar camp. I like upgraded parts, no doubt, and I liked this idea a lot, but I think I would need to be under $100 for the pair.
kbuskill
kbuskill
NE. FL.
Same here
I understand completely. Unfortunately I have no control over any of it. I just brought forth the idea to them and this is what they came up with.
I really thought there would be more interest because so many people have issues with them, but I also thought they would be more reasonably priced.
Of course I guess those things kinda work hand in hand. One off parts are expensive. 10 off parts aren't that much cheaper... lol 100 off might be but this idea may never get there.
Meccanoble
Georgia
I think its good that you keep bumping this as I just seen this for the first time today. As someone that had to replace both, was happy to see this but the price difference is significant and I can understand why. Most people replacing this would need a quick disconnect adapter to remove. Maybe if these came with that so people could save on buying a whole kit...just thinking of ways to combo and save.
I wonder if they could make a transmission pan that was easier to remove/maneuver. I'm sure that would be a hit. I bet if these quick connect installs were harder, it would be a bigger hit.
davidzog
I replaced mine with Dorman units which seemed to be somewhat sturdier than the oem....I swapped them at 98,000, even though nothing was wrong with them....
scottd
