89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Here is the mileage and hours at the time of engine replacement
89Suburban
SE PA
I know the dash cluster was replaced at some point I’m assuming the right hours were programmed back into it.
89Suburban
SE PA
I remember when the previous owner told me he had it replaced and that was about 3-4 years before I got it from him at 290K. He did a majority of highway miles as it was a sales vehicle that did a lot of traveling.
SpareParts
North Idaho
@89Suburban
I had a 2008 Escalade EXT with a 6.2 that lost oil pressure and had lots of sparkles in the oil at about 160K. Had a new GM 6.2 installed. About 6 months later it started loosing oil pressure with maybe 5K miles on it. Sold it, Gave the guy all the warranty paperwork and wished him good luck.
I loved that truck but hated it at the same time.
I truly am hoping you have better luck then I did.
89Suburban
SE PA
@89Suburban
Damn that sucks brah. I hope so too. This is a reman unit from this place:
Good question. I was hoping it was residual. Looks too clean though. Only been on the road for 4 days. We shall see I guess.
residual???? no..... best take it over there on Monday to verify in the meantime take a rag and wipe it all clean and then see how it looks again when they get it up on a lift
mikez71
Hope it's not the rear main.. I did one on my bmw i6, I took care to line up the bottom of the rear seal cover, so it was flush with bottom of the block. I think I screwed up, it should have stayed centered on crank and any oilpan misalignment would probably be taken up by the gasket plus dab of silicone on the corners. That one drips a little. That crank also had a groove worn into it from the original seal..122k miles, I was surprised by the groove..
mikez71
tightened (squeezed) my passenger mirror defroster wire connectors. They were still connected, but rather loose. (thanks for the suggestion @Tonyrodz!)
I think it happened from the old mirror flying off when I removed it.
j91z28d1
nothing worse than having to go back to the shop. I dread dealing with people.
good luck.
Drewphil
