2021 Tahoe PPV massive oem brakes, 16"
Jimbo123
Going in like butter
RTLINGR2
Sanford, Fl.
The coating on the rotor will wear off. Do a good burn-in/seat the pads, let them cool, then do it again couple hours later. The 1st time you do it, you will still see the coating, and it will start to wear off. The 2nd time should be good. The police pads put off some dust, so just stay on top of cleaning the wheels. They'll stop and shouldn't get any noise out of them. The Rebestos wear nice. More milegae out them than the oe stuff.
Jimbo123
The braking difference is now where my previous Germans were, as far as pedal feel and application. Then under a hard stop, holy cow, it's glorious!
RTLINGR2
Sanford, Fl.
Thats awesome! If you dont mind, where did you source the calipers and cost?
As far as your 21 Denali, what was the the caliper on it? 2 piston, 4 piston, and did it use a caliper mounting bracket like previous generations or is the bracket deleted like the ppv caliper? Thanks!
Jimbo123
The original fronts were 4-piston. The calipers bolted up perfectly, as I also opted to pull the hubs to install the larger backing plates. With the PPV backing plates, it required no shimming of the caliper, as it aligned perfectly over the rotor.
Outlined below is my entire parts list I got from Rock Auto. I had to source the pin kits and caliper bolts from a local Chevy dealer, as Rock Auto didn't have inventory. One thing I learned is the brake pad wear sensor I ordered for the front, doesn't work due to the height needed for the sensor to clip in before it 90's, however using a rear brake pad sensor resolved that, as it has more height. I've highlighted that sensor in red that DOES NOT work. I ordered 8 banjo bolt washers, just in case I needed to take them off again, but didn't need to, so you'll only need 4. The only thing I had to come up with an idea for was the brake hoses, as the bracket off the existing hose still goes in the same spot, but where the hose enters the calipers, is at a different spot and the hose now wants to be super close or may rub on the upper part of the knuckle. However, i resolved this by wrapping a section of those brake hoses with rubber fuel hose and secured it in place.
11546469 - Caliper Bolt x4 $2.85 each
85153957 - Caliper Pin Kit x2 $37.21 each
GM GENUINE​
84793057Caliper
$ 394.99​
$ 0.00​
1​
$ 394.99​
GM GENUINE​
84793058Caliper
$ 397.79​
$ 0.00​
1​
$ 397.79​
GM GENUINE​
11569590Banjo Bolt
$ 12.17​
$ 0.00​
2​
$ 24.34​
GM GENUINE​
21012386Banjo Bolt Washer
$ 0.45​
$ 0.00​
8​
$ 3.60​
GM GENUINE​
84495310 (84763236)Brake Backing Plate / Dust Shield
$ 11.79​
$ 0.00​
1​
$ 11.79​
GM GENUINE​
84495309 (84763235)Brake Backing Plate / Dust Shield
$ 11.79​
$ 0.00​
1​
$ 11.79​
GM GENUINE​
11609271Rotor Lug Stud
$ 5.23​
$ 0.00​
2​
$ 10.46​
GM GENUINE​
84693643Brake Pad Wear Sensor
$ 14.15​
$ 0.00​
1​
$ 14.15​
GM GENUINE​
84688287Brake Pad Wear Sensor
$ 14.11​
$ 0.00​
1​
$ 14.11​
RAYBESTOS​
582799PRotor
$ 95.79​
$ 0.00​
2​
$ 191.58​
RAYBESTOS​
SP2407PPBrake Pad
$ 50.79​
$ 0.00​
1​
$ 50.79​
RAYBESTOS​
SP2174APPHBrake Pad
$ 30.99​
$ 0.00​
1​
$ 30.99​
RAYBESTOS​
582457PRotor
$ 69.79​
$ 0.00​
2​
$ 139.58​
Shipping​
Ground
$ 85.95​
Tax​
$ 117.46​
Order Total
$ 1499.37
RTLINGR2
Sanford, Fl.
Good write up. Thanks for sharing. I was referencing your stock components for brake upgade on my 05 tahoe. The 13" rotors and a 4 piston calipers would stop better than my current 12" with 2 piston. But been researching the 16" 6 piston as well.
As far as your sensor and hose bracket issues. By chance did you look up those parts for a 21 up ppv tahoe? May be what you need.
Rotor and pad info i gave out is what we use as replacement components over the oe in our ploice fleet.
Jimbo123
Oh, yeah that'd definitely be an upgrade, but I tend to keep stock stuff around and throw the vehicle back to stock if I decide to sell or trade-in. I'd recommend this setup over my 21 stock setup.
I did look up the part numbers for both and the left side brake hose has a different part number, by one digit, but the passenger side was the same. I'm sure it would be fine and wouldn't rub through, I'm just an@l and over-cautious.
RTLINGR2
Sanford, Fl.
I did look up the part numbers for both and the left side brake hose has a different part number, by one digit, but the passenger side was the same. I'm sure it would be fine and wouldn't rub through, I'm just **** and over-cautious.
Cool. I get it.
Jimbo123
Since your new caliper has 6 pistons, 4 more than previous front setup, does the master cylinder need replacing also?
Negative. Comparing the PPV to my Yukon XL and the part numbers were exactly the same, including lines. I believe they went smaller pistons to account for the master setup. After doing a 2700 mile road trip, these brake are worth their weight in gold. Could not be more happier with my decision to go with them.
wildchev67
This thread is great for info, thanks all! In the last month I have swapped my 2011 Escalade, and 2024 Yukon.
Below is the list of what I used for my 2024 Yukon swap. The PPV j55 Tahoe has different brake hoses listed, I have confirmed those fit. Also as stated before, the rear wear sensor works for the front calipers.
I ended up customizing a 18mm socket so I could remove the hub bolts without removing any ball joints, just need to tap the axle back a little.
I will keep an eye on brake dust, I believe it was said the Brembo pads make a lot of dust? My 2011 Escalade has power stop pads, so I should be able to compare.
PPV J55 2021+ brakes:
16" Rotor weight 87839222 40.8 pounds
6 piston caliper 84793057 weight w/pads 19 pounds
2021+ SUV standard brakes:
14" stock rotor 29.2 pounds
4 piston caliper w/pads and brake hose 19.8 pounds
GMt900:
13" rotor 25.4 pounds
2 piston caliper and bracket 18.8 pounds
2021 PPV j55 Tahoe, VIN to use 1GNSCLED6MR283980
GM GENUINE
84793057​
Caliper (Drivers Side) Brembo​
GM GENUINE
84793058​
Caliper (Passenger Side) Brembo​
GM GENUINE
11569590​
Banjo Bolt x2 ( M10x1)​
GM GENUINE
21012386​
Banjo Bolt Washer x4​
GM GENUINE
11546469​
Caliper Bolt x4​
GM GENUINE
84495310 (84763236)​
Brake Backing Plate (Passenger side)​
GM GENUINE
84495309 (84763235)​
Brake Backing Plate (Drivers side)​
GM GENUINE
84688287​
rear pad wear sensor (longer lead and reach on sensor end)​
GM GENUINE
84987498​
Front Brake Pads (Heavy Duty, hardware not included) Brembo​
GM GENUINE
87839222​
Front Brake Rotor (Heavy Duty) x2​
GM GENUINE
86555794​
Caliper hardware kit (pins and pad spring plate)​
GM GENUINE
84956404​
Front Left J55 brake hose (w/banjo bolt and washers)​
GM GENUINE
84956405​
Front Right J55 brake hose (w/banjo bolt and washers)​
alternativeNapa
FLT FT9637​
Fleet brake pad (includes caliper hardware)​
alternativePOWER STOP
AR82209XPR​
Rotors (both sides)​
Z37-2407​
Brake Pad (both sides, pins included)​
RTLINGR2
Sanford, Fl.
Hey everyone, just giving you all another option in replacement pads and rotors. The Power Stop brake rep came by the shop the other day. Set us up with a complete set of front and rear pads and rotors for 21 and up PPV Tahoes. These are supposed to address the brake squeal and increase the wear mileage over the OE pads. We haven't installed them yet, so we don't have any data to report. Just haven't had a tahoe that need a brake replacement yet. Here are the part numbers and the hardware the front pads come with.
Twov8sandat4
I installed the exact combo of pads/rotors you have in those pictures on my 07 Escalade. I have to say I have never seen so much brake dust in any of my vehicles. The stopping power is phenomenal though.
I am going to change pads to something with low dust when it's time to do the rear brakes (soon) and have matching front and rear pads.
Thanks.
RTLINGR2
Sanford, Fl.
Thanks.
Thanks for the heads up! I will keep that in mind for our fleet.
Now, on my 04 2500 sub installed Wagner OEX pads all 4 corners. Stock rotors. They stop good with and without a trailer, low to no dust and quiet. They were advertised to knock off additional 50' stopping distance. These have been on for a while, but I'm not ******* brakes, they wear very good. When they do wear out I will buy them again. When the pads wear out on my Tahoe, it will get the OEX's also.
Now I have not checked into If the OEX's are available for replacement on the ppv. If they are, I would try them.
Twov8sandat4
That's good to know. My plan was to do EBC yellows all around as I wanted to install C7 calipers in the back, but if there are other pads, I am open to it.
Thanks.
Jimbo123
Hey everyone, just giving you all another option in replacement pads and rotors. The Power Stop brake rep came by the shop the other day. Set us up with a complete set of front and rear pads and rotors for 21 and up PPV Tahoes. These are supposed to address the brake squeal and increase the wear mileage over the OE pads. We haven't installed them yet, so we don't have any data to report. Just haven't had a tahoe that need a brake replacement yet. Here are the part numbers and the hardware the front pads come with.View attachment 428044View attachment 428045
I did swap out to these pads. WAYYYY less dust, no squealing, and overall very happy. They grip a bit less than the original semi-metallics that you posted, but it's a land yacht, not a sports car.
NYBRD
GMt900:
GM GENUINE
84793057​
GM GENUINE
84793058​
GM GENUINE
11569590​
GM GENUINE
21012386​
GM GENUINE
11546469​
Caliper Bolt x4​
GM GENUINE
GM GENUINE
GM GENUINE
84688287​
GM GENUINE
84987498​
GM GENUINE
87839222​
GM GENUINE
86555794​
GM GENUINE
84956404​
GM GENUINE
84956405​
alternativeNapa
FLT FT9637​
AR82209XPR​
Z37-2407​
/Just ordered all these parts thanks to your help helpful post with all the part numbers, will be installing on my 18 Tahoe. Thanx
I
wsherring
GMt900:
GM GENUINE
84793057​
GM GENUINE
84793058​
GM GENUINE
11569590​
GM GENUINE
21012386​
GM GENUINE
11546469​
Caliper Bolt x4​
GM GENUINE
GM GENUINE
GM GENUINE
84688287​
GM GENUINE
84987498​
GM GENUINE
87839222​
GM GENUINE
86555794​
GM GENUINE
84956404​
GM GENUINE
84956405​
alternativeNapa
FLT FT9637​
AR82209XPR​
Z37-2407​
Thanks for the list - helped me out a lot putting these on my 2023 Suburban.
4 things that weren't clear to me until I intalled them:
1 - If you replace with the J55 brake lines above, they come with banjo bolts and washers, so you don't need to buy extra.
2 - The Powerstop pads come with the pins and springs for the calipers, so you don't need to buy the separate springs and pins.
3 - Only 1 brake wear sensor is needed - it's on the driver's side only
4 - I read elsewhere that it's recommended to replace the axle nuts instead of reusing since they deform on installation, so I used new ones.
BadDaddy2003
