Front differential rebuild - looking for a walkthrough
SEMark
I am gearing up to do a rebuild of my front differential on a 2012 Yukon XL SLT (5.3L with 8.25" front diff). I've watched several Youtube videos, and it all looks to be reasonable to do.
I am wondering if there is a service manual available that would include all the torque specs, etc. and walk through the disassembly / reassembly procedure. I've found some recommendations for Alldatadiy online, but before I pull the trigger on the $20 for that, could anyone comment on if that kind of information is available on that site? Or is there another resource that covers the procedure?
Thanks, and sorry if this has been asked before! I tried searching, but there were a lot of false results.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
Have you checked to see if you have the correct tools for this work. Good luck but if I was doing it for the first time, I would have a trained friend with me. I was in the field 35+ years and have never done a diff rebuild. One thing I do remember is that when you install new parts, start out with the existing shims/spacers in the same position and adjust from there.
ivin74
05 NBS Nali
Htown, Texas
I rebuilt mine several years ago and has been trouble free since.. The specs are on post 7.
Please read thru the link below. I hope it helps.
I have watched it done before, when I had time, and always felt, "there is an art to it".
AllDataDIY has everything you need. Now the shop manual uses the special tools to do things, the videos on youtube use a screwdriver and a hammer!
S
SEMark
OK, progress so far. I opened up the diff but did not find any evidence of any blown out tapered bearings. But since I'm in here and have the parts, I'm going to replace them anyway.
I did find that one of the backlash adjusting rings was loose. I suspect that it backed off and allowed extra play in the gear mesh, and resulted in the gear noise I was hearing. This diff uses a different style of adjuster than is in the tutorial. I've attached pictures. Does anyone know how these ones are supposed to lock? The one side is tight, but the other one I could spin by hand. I can't see the difference between the two though.
Thanks,
S
SEMark
Sorry, triplicate post
ivin74
05 NBS Nali
Htown, Texas
Thanks,
The adjuster rings should be a two piece set up. The inner section screws in/out. You need the spanner tool to turn it and adjust it. You can make one using a large socket, that's what I did.
The adjuster lock ring locks it in place.
Yukon Gear & Axle (YT A08) Spanner Tool for GM 8.25 IFS Differential https://a.co/d/6u4Nbp6
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Thanks,
I am familiar with this as I had a similar issue.
Those adjuster locks are soft and get driven into the splines after the lash is set.
My thread on it here:
j_jerry79
