lspann3525
- Joined
- Feb 22, 2023
- Posts
- 222
- Reaction score
- 220
Well guys after replacing the rear main seal on my 2008 tahoe z71 5.3 250,000 miles the oil leak has returned. It's not pouring out oil like before but it is seeping somewhere I just hope not the RMS again. Im not getting any oil spots in my driveway but I did notice a very small amount of oil on the left and right side of the bellhousing where it meets the engine block. Its not a severe leak just a very small drip. On top of that I took a trip from Mississippi to Georgia which was about 1000 miles to and from. And when I made it home and I checked the oil and it was at the bottom of the oil dipstick right where the crosshatch starts. Im currently running 5w30 and plan to go to 10w30 just in case the engine is burning oil with all those miles. With the engine running im not able to see any oil leaks it just overtime. Wile under the truck I removed the access hole cover and it's clean as a whistle inside.
I have recently changed the following parts. Replaced RMS with Dorman Rear Cover with seal, Valve Cover Gasket, Crankshaft Sensor, Oil Pressure Switch/Screen. Even thou my oil read at the bottom of the oil dip stick the alert message stop engine has not appeared. After doing some more google on oil leaks I found a couple of threads saying the valley pan gasket could be leaking and it's a known issue with the trucks that have AFM.... Im having a hard time trying to identify if it's the valley pan anyone have any ideas on checking the valley pan?
