j91z28d1
apm? air pressure? if so as far as I know the air pressure commands are for testing only
I looked again. it seems to be a hybrid thing. under powertrain, accessory power module, special functions. I get apm setpoint control.
while in there I did see the cooling fan test for relay 1, 2 and 3. these trucks use a resistor pack on each fan to make 3 speeds. 1 sounded like low speed and both fans came on. 2 sounded litter faster and both came on. 3 was crazy loud but only the passenger side came on. guess I gotta dive into that and see with summer coming. I remember looking at the wiring diagram once and getting a slight headache lol. guess I'm diving back in.
I'm not even sure it should run both for just relay 3 turned on. I turned the ac on max with the windows down but it's not hot enough, high 80s at best. could only get high side pressure up to 198 and relay 2 commanded on. 3 never was.
might be a hybrid thing, on the gas trucks both fans come on no matter the speed.
that's how I found out one of my fan motors was bad, right side was not spinning reached down to see if it was froze up bumped the wire harness and it kicked on, discovered the motor was going bad and had partially fried both sides of the connector
j91z28d1
yeah its a hybrid thing. I think I finally wrapped my head around it after having to draw on the diagram lol. 3 trigger wires from the ecm controller 5 relays to give them 3 speeds. I think pro damand labeled the one low but it's also the high speed too. so all 3 input have to be on you get hi to both fans and tech 2 was just triggering 1 for #3. there is an option 1,2 and 3 but when I did that it sounded more like med. the one on hi sounded much louder but I didn't have the truck on, just the key forward. so running both fans on hi off the 12v was probably dragging the voltage down.
I'll have to wait till it's hotter or maybe block some the air to the condenser, get the hi side up enough for request 3 to enable and see what the fans do.
I love this Griot’s Speed Shine this time of year. The Silvy only gets dusty and if I wash it I have to towel dry it or else it gets water spots. This thing looked terrible and I cleaned it in about 10 minutes with the Griot’s and a microfiber towel. Ready for tomorrow’s grocery run. :happy107:
I love this Griot’s Speed Shine this time of year. The Silvy only gets dusty and if I wash it I have to towel dry it or else it gets water spots. This thing looked terrible and I cleaned it in about 10 minutes with the Griot’s and a microfiber towel. Ready for tomorrow’s grocery run. :happy107: View attachment 400557
I have the same tire inflator. Branded "TiGaAT".
Charlie207
LFOD, New Hampshire
Went for a drive up to Acadia National Park. I was able to cash in my government service for a free lifetime vehicle pass, so that was cool.
Rig did fine; no dramas on the drive to/from the park and around Bar Harbor. Stopped at two breweries on the way up, and five in the ride home, but we stayed in Portland on the way back to break up the return trip. Ate nothing but steak, crab and gobs of lobster for four days.
Campsite was nice and in a good spot.
Top of Cadillac Mountain. We got there as early as we could, and had most of it to ourselves for a mimosas and scenic overlooks of the ocean.
(How not to take a pic.)
Awesome trip, and can't wait to do it again.
pwtr02ss
Tennessee
Maine is my favorite state. Steph and I try to visit once a year. Thank you for sharing and making me jealous!
SpyShops212
Yes I agree! I took the family once every couple of years to Portland. There is so much to do in the summer. I love to go on the lobster fishing boat then when you return there is a place to cook your lobster you just caught and eat the New England clam chowder in the bread bowl. The sail boat ride is nice. In Portland they operate on the honor system which is cool. I stop to Kennebunkport on the way back to NYC and buy the Maple Syrup on the homemade glass bottle. Damn I need to go this summer.
SpyShops212
bumper cover had to come off?
Bumper cover does not need to come off to change the steering rack. Only the underside protector with the four bolts. I would change the inner steering tie-rods and use Duralast Gold HD also the ends using OEM or at least grease the fittings. You are going to need an alignment. Don’t worry about the dash light with will go off once you align the truck.
lol, I don't need to change mine just was curious if the bumper cover had to come off for some reason I changed the one in my 03 a couple times, and a few older vehicles in the past.
but why on earth would you have a dash light from changing the rack n pinion?
I could see maybe if you totaly fubar'd it up so bad the yaw sensor was out of whack or something....
Sparksalot
Bastrop County, Texas
Ordered pads & rotors for front/rear from Rock Auto. I ordered the exact same parts as I did two years ago, and they were about $70 more expensive this time around.
Damn. How hard do you drive it?
I’ve had thecopcar 4.5 years and 40k miles. Haven’t changed them yet.
Drewphil
