YukonHog
Just get the sizes, etc. and you can look on Ebay, etc. I bought an Alpine X308, and the surround to fit. I went directly to both Alpine and Panasonic sites to find out what would fit
What do you like/dislike about the Alpine 308 system? Did you have to get the XM tuner adapter for satellite radio to work?
CaptainAmerica1
Arlington TX
Also, years ago I remember someone doing a write up for modifying the stock airbox and inner fender to allow more air to flow through? Does that sound familiar?
Doubleive (sp) or iamdub posted some details on this air box mod and I happen to have the photos saved, diving into this tomorrow believe it or not… I hope whomever it was doesn’t mind me sharing his photos…
St. Louis
Waste of time removing that sheet metal and plastic on the airbox unless you plan on adding much more horsepower
Mine starts here: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1451013
As @gooffeyguy pointed out, you can't expect any power gains from opening up that hole. If anything, you'd get a small boost from better insulating the air box by replacing that seal. Still, likely nothing you'd feel. But I've seen a huge improvement comparing my before and after IATs so at least that part is a valid mod.
Sparksalot
Bastrop County, Texas
I think it was @iamdub . I did the same on mine, and it worked well.
RooTBeeRthe1st
Monz11
Da Burg, Fl
I love it because the screen is so much bigger than the stock radio. The Only thing, I wish the installer would have used the stock speaker in the headliner, instead of attaching the new one to the windshield. I bought the xm tuner but have not had it installed yet.
justchecking
Military
SW Ohio
If you have Sirius xm you can also use the app in CarPlay. At least when I had it the app was better for me than the tuner.
Filled up and tested last night, tested right at 85% given 1-2% error for my amount of fluid pouring.
Psychical sensor still reading 73-74%
Wondering how accurate the sensors are, and if my sensor or maybe wiring are causing low reading.
How old are the sensors and how far did you drive when it settles on 73%? I bet it'll change again if you drive it today.
dizhai
