This site has the exploded view, might be easier.
www.gmpartsdirect.com
thats weird, its showing it on the parts website I was directed to from you guysI don’t see that info on the GM website, where did you see it?
It’s because it was right in front of my face!thats weird, its showing it on the parts website I was directed to from you guys
HahahaIt’s because it was right in front of my face!
I'm working the right axle shaft, replacing the seal. Didnt realize there was a lock ring on it and started trying to hammer the shaft out of the housing which bent the 2 washers.I guess I don't see what part of the diff you're working on. Could you describe it a bit more in detail? Do you see it in the diagram on the link that @Rocket Man posted?
Nice!Forgot to post an important update actually today! Got the pickup tube oring in, new pan gasket and used an acdelco filter, she now idles warm at around 38psi of oil pressure, compared to 20-27 before! And at 1.5k rpm it has around 50psi of pressure compared to the 35 before!
This is why I bought a subscription to alldatadiy so I have access to the factory service manual.Theres must be 2 different styles of these axles. The first video I linked is different than mine, it has a giant snap ring up top, where as mine just had a little clip like in the second video. Also seems in the first one they dont have the second washer that mine has.
Video that mine is NOT like:
Video that mines exactly the same as:
Did they change them at some point?
Totally worth it!This is why I bought a subscription to alldatadiy so I have access to the factory service manual.
Not as fancy as the Alldata online, but I did go out and get the PDF FSM from an Ebay seller. I have mine on my Google Drive. Maybe not as easy to navigate as Alldata, but I can have access to the manual for my model year if I need it. Sometimes it is nice to have diagrams in front of you when watching some of the Youtube videos as a reference. Exploded views, parts lists and wiring diagrams are really handy. They also have Tech 2 specific diagnostic steps outlined, which can also be helpful.This is why I bought a subscription to alldatadiy so I have access to the factory service manual.
Does the FSM have sensor data ranges to diagnose?Not as fancy as the Alldata online, but I did go out and get the PDF FSM from an Ebay seller. I have mine on my Google Drive. Maybe not as easy to navigate as Alldata, but I can have access to the manual for my model year if I need it. Sometimes it is nice to have diagrams in front of you when watching some of the Youtube videos as a reference. Exploded views, parts lists and wiring diagrams are really handy. They also have Tech 2 specific diagnostic steps outlined, which can also be helpful.
I agree... You need all the help you can get! Anything you can get your hands on, preferably before you actually need it...
Yep, they all clunk when shifting from 2wd to 4 low which has to be done in neutral, 2wd to 4wd high is silent normally.
