Help needed with P0171 & P0174 running lean at idle. My fault!
Kapitein
The Netherlands, Europe
Hi folks,
Looking for some advice, I've come as far as I can go without further help from people more experienced with the platform.
A few weeks ago I replaced the oil pressure senor on my 07 Yukon XL 6.2. That all went great, but during that process I had to remove the two PCV/Evap lines that run down the side of the valve cover on the drivers side of the motor. One I believe is dirty air and goes from the inlet manifold to the valve cover, the other is a clean line that goes from the evap valve on the side of the engine, to a port on the rear.
After replacing the oil sensor, I put everything back together there was a really loud hissing noise, the motor ran like crap and the short term fuel trims were up at +50%. After playing with those two lines I managed to get the obvious hissing noise to go away, but at idle the STFTs would go from <1% up to +25ish%
This trips the CEL for P0171 and P0174 system too lean bank 1 and bank 2.
To cover my ass I ordered up the 2 lines and replaced them. Both had a broken or cracked boot/clip (see photo). This significantly helped but has not fixed the problem. At idle the STFTs still cycle up to around +10-15% (and then back to low values) which sets the CEL and triggers the stabilitrak warnings etc. The car also has a slightly rough idle.
Using live data I can see the problem is only at idle... at 2500rpm the STFTs are 0% and the warnings disappear and the car drives perfectly. So I have air ingress/vacuum on the intake side and its driving me nuts.
To cover all bases I have changed the whole inlet tubing an MAF sensor for a known good one I had on the shelf, made no difference.
This is obviously something I have caused when changing the pressure sensor, but can anyone offer advice on what to check next or do next... smoke test maybe?
See attachments for various screenshots and PIDS when the code(s) set.
Appreciate any and all input, thanks!
donjetman
if you removed the intake manifold? you may not have put it back together correctly?
My only suggestion is to go back and check your work, both the first work and the follow up work. Remove those 2 lines, check to see that they are seating and sealing properly, use a mechanics mirror and a flashlight to look around the area you were working in. Might be another vacuum hose or even a loose electrical connection to a fuel injector. It might be right in front of your face too. Maybe you pushed or pulled on something that didn't like being touched.:p
Foggy
KS
Agree with rocket man....
You may have inadvertently touched a vacuum/ air line that was already
in a deteriorated condition
That's a pretty big air leak for the FTtrims to go to 25* quickly
Triple check all that good stuff
On the app that you're using, what do the three blue values above each PID value represent? L to R, I assume "low reading" "?????" "high reading"? What's the middle value?
Since those are STFTs, the current PID value is only for this ignition cycle since STFTs reset.
B-train
In your wiggling around under the hood, is it possible you knocked the PCV line off by the intake tube for the throttle body on the passenger side of the motor up front? Just throwing stuff at the wall at this point.....
I agree with all of the above as well. I've done the same job and it seems that you almost have to lay on the engine to get it done
Kapitein
Kapitein
Thanks for the input so far. I have been back today and double checked everything, and to be honest it was as expected... it looks fine!
I checked the brake booster vacuum line, and when I pushed on it, there was a slight click.... so I wondered immediately if I had found the problem....
Unfortunately not, although it seems the trims are slightly better. Its still running lean on bank 1 and 2 and its now recording short term trims at about -4% average.... thats enough to trigger the pending CEL/actual CEL and trigger the stabilitrak warnings at idle.
As soon as you are driving/giving gas the trims are perfect and it performs great. ECU PIDS are showing zero misfires. Its not a randomly occuring issue, im sure of it. This has to be down to me messing around in there.
What would you do as a next step? Replace the booster line just to be sure? Maybe it has a bad connection. If I listen when the car is idling I *think* I can hear a slight hissing noise above the sound of the valve-train etc, but its incredibly difficult to tell.
Smoke test at a mechanic?
I hate problems like this, especially when you cause them yourself. It was running great until I changed the pressure sensor.
Kapitein
Kapitein
The middle value is the average, since last engine start I presume.
Kapitein
Kapitein
I disconnected the battery for 5 mins to reset the LTFTs. They almost immediately run up to +24.55% on idle (the max). But drop to completely normal values the moment you give it throttle.
I also did the water test on both banks for the inlet manifold gaskets. Zero rpm change and zero steam out of the exhaust, engine continued to run the same. So as far as I can tell that rules out my intake gaskets as the problem.
Seems like its a big vacuum leak on the intake side of things, but where :(
Kapitein
Kapitein
-4% fuel trims won't trigger the CEL; besides, that means it's in a rich condition, not lean, taking away fuel. We'd all have CELs if that was the case.
Sorry thats a typo. It was +4%. But indeed +/- 10% is considered normal and wont set a CEL.
I presume now having enabled some more PIDs on my scanner that its the LTFTs being pegged at +25% thats causing the CEL.
Kapitein
Kapitein
Just thinking out loud now... If the oil pressure sensor wasn't tightened down quite tight enough, could that cause a vacuum leak?
Some scanners will allow you to reset the LTFTs; that would be something to try. I'm wondering if disconnecting the battery for a few minutes and touching the cable ends together, or turning on the lights to drain any residual power, would reset them.
Kapitein
Kapitein
I managed to reset the LTFTs by disconnecting the battery.
On closed loop they rise to 25% (max) at idle quite quickly. On the road/under throttle they immediately lower to normal levels.
worleytrev93
