Never miss a discussionGet a roundup of the newest threads delivered to your inbox. Enter your email below and pick how often you'd like to hear from us — no account required, and you can unsubscribe any time.Double opt-in — we'll email you to confirm. Unsubscribe any time.
Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
You can have the valve cover off in 10 minutes and get a visual on the action in the #4 intake and exhaust valves. The stuck lifters I have found you could feel far more movement on the rocker arm on that stuck lifter.
Well another update. Figured out the shudder I was low on trans fluid due to a small leak from pan which I have fixed yesterday while doing fluid and filter change as well as oil and filter change while I was under there. Did an exhaust back pressure test and at idle both sides were around 1 psi and at 2500rpms was around 2.5-3 psi. I guess all that’s left is to pull valve cover. From readings I’m thinking stuck/burnt intake valve or lifter issue. I’m 99% sure we ruled out everything else
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
