Geotrash
Dave
Richmond, VA
How far will one bottle take you?
I don't know - I haven't put it in the gas tank. :happy175:
Seriously though, I'm still working through my first bottle and have maybe another 2-3 cars' worth of solution left. It only requires a light mist on the finish, which you then spread around with a microfiber towel to get an even film. After that, just buff it with a 2nd, clean and dry microfiber towel to get the high luster. You can do a whole XL Denali in 10 minutes.
St. Louis
Gave both Denali's and our LR2 a fresh ceramic spray wax treatment with Griot's Garage 3-in-1 Ceramic Spray Wax. Super impressed with this stuff. I've been using it every 2-3 months for the past year and the water still beads and grime doesn't stick right up until the next treatment. I didn't take pictures of the Denali's but did take some of the finish on the LR2. Keep in mind that it's 14 years old with 230K, and has been parked outside for the past 5 years.
Says it's Safe for plastics.... Should use it on the dash to help keep it from cracking
CaptainAmerica1
Arlington TX
Sounds like a 2am infomercial
St. Louis
I have one of those, but it would've been too high and I would've been bent way over.
I sat on the ground most of the time but after disconnecting the upper ball joint and tie rod I was squatting or on one knee using my leg to help hold the spindle/hub/brake kind of in place while strong arming the prybar and placing the spacers and aligning the bolts all at the same time.
It's not my entire thigh that hurts, just right above the knee and to the inside. It's weird, usually it's my lower back that would be sore for a day or so, not my legs.
Ihaveatahoetoo
