Oil Catch Can
Big Mama
Virginia
I emptied mine today after 2k miles and got just under 1.5 ounces. It was dark but in the sun had a redish tint?
waynehead99
Why? What does it do? What breaks if you don’t have one?
Not so much that something breaks...
Normally an engine will have some oil get past things and gets into the intake (PVC valve), on engines (before direct fuel injection) that oil would hit the intake valves and the gas from the carb or the fuel injectors that were above the intake valves would wash it off.
Now on direct fuel injected engines (like the 5.3 and the 6.2), the injector is directly in the cylinder next to the spark plug and below the intake valve. The oil still gets into the intake, but now has nothing to wash it off because the fuel doesn't come from above any more.
These cans catch that oil before it gets into your engine, to keep things cleaner and help with carbon buildup. Personally I don't know the science behind it if it truly is something that adds longevity to the motor or not, but the logic makes sense, and I am planning to get one for myself one of these days.
Aren’t Catch cans more suited for supercharged engines?
Nope. And, there is more than one thread here on the Forum that goes into great detail on why oil catch cans are also good for these motors. One of the main reasons are a result of direct fuel injection introduction to these motors, and as a result, there is no longer the capability of the solvent action of gasoline washing the backs of the valves, to keep them clean of deposits.
Hobert
Downers Grove, IL
I forgot to mention, I checked my oil level which I'm good but man was it dirty (black). I'm only at 3524 and did not expect oil to be dark at this point. Basically looks like what came out the can.
Told you I would check my can at 600 miles but here it is at 3500 miles. I caught about 6 ounces and the color of the oil on the dipstick was much better. My first 3 changes the dipstick was very dark, like black. This is after 3rd oil change since new and the oil looks more like I would expect. Black color maybe a result of engine break in?
ljn21
I can’t seem to find a can that fits the 2022 Yukon/Tahoe…anyone have a link?
SSGUNNER
Don’t know if anything changed for 22’s but if it didn’t you can use a 19-21 Silverado can (elite) and fits right in there.
R32driver
Interesting info in this thread. I've never really seen these on anything other than turbo or supercharged engines but makes sense with these being direct injection engines. I checked my oil at 4500 miles before a road trip that I knew was going to push me over 5k miles before I would be home for the first oil change and the oil looked like it was brand new out of the jug.
SSGUNNER
shekmark
Senior Member
Jersey Shore
I just bought a UDP single catch can. Quality is as described by the OP…excellent. I have not installed yet. I am wondering about warranty issues. Nobody seems to have had a problem or I suspect it would have been posted by now. It looks seriously OEM so I wonder if they would even notice. I guess if my engine blows a lifter I would convert back before towing.
SSGUNNER
You don’t have to do that. If there is ever a case of denying you warranty they have to prove the catch can is the result of your “engine blowing”.
SSGUNNER
For more peace of mind - Here is an excerpt from a search I found on the act mentioned above:
  • The Magnuson-Moss Warranty Act makes it illegal for companies to void a warranty or deny coverage under the warranty because an aftermarket or recycled part was used.
H1Chester
Just ordered this guy:
Yes it is pricey. I've been running Team RXP Catch Cans since my 2010 Camaro. They make an awesome product MADE IN AMERICA. Two things I really like are that it is a nice big can and the drain at the bottom which makes emptying the can very easy.
morig
I just installed the J&L catch can and notice a slight hissing from the catch can when I have my head under the hood. With the hood shut I can’t hear it. Is this normal? Engine seems to be running fine but curious if I should be concerned about the hiss or if it’s just air traveling through the can/filter.
Big Jim
