Tonyrodz's Tahoe Build Thread
I finally figured out why it kept throwing the belt--idler pulley.20201120_114231.jpg
Advance had given me the wrong one and I tried to make it work--FAIL! I got an oem one from numb nuts and it's GTG!! Runs like a champ.
I think I fixed the blinker issue. I just messed with the bulbs. They work again.
The beauty cover is flopping around. The part that it hooks into is missing--I think.20201120_123656.jpg
Anyone have a pic of it?
I miss my 10.5 Taylors :mad:.20201120_123746.jpg
This bare ended wire is just an extra ground I added. I don't have a big enough eyelet to add.20201120_123856.jpg
So pull it down for more wiggle room? It's pushed up too far?
This is what it looks like to me. Pulling it down would clear the prop shaft and align the flange where it connects to the rest of the system. My Y-pipe is about 1/2" above the bottom of the cross member that it goes in front of. With all them slip-fit connections, you have a lot of adjustment. You still may need to crush the Y-pipe a little, but it'd be a lot less. You may actually get plenty of clearance at the prop shaft and need to squash it a little where it passes on top of the cross member to let it come down enough. Whichever requires less squashing and/or gives more clearance.
Bear77
South FL
I was sure it the power steering pump pulley! Glad you figured it out.
Might have a one hiding if you need it
What size is that wire?
These pic angles don't show the height of my crossover pipe in relation to the cross member. They actually make it look really high. But you can get a visual of the two points in question. Loosen all three slip-fit connections, and let the Y droop down as much as the slack in the slip-fits will allow but remain above the bottom of the cross member. They'll try to realign as you tighten the clamps, so wedge a 2x4 or something on top of the Y, against the floor of the body to hold it down and into position while you tighten everything where you want it. You can mark everything very carefully with a permanent marker, remove the Y and have someone weld it together so the clamps and slip-fits will never be a problem.
randeez
south florida
no where near the front DS
when i had the speed engineering headers/ypipe on mine i think the crossover pipe was right at the bottom of the transmission crossmember, maybe even a hair below it. never really tried to push it up to the prop shaft
pwtr02ss
Tennessee
So CLEEEEEAN
pwtr02ss
Tennessee
I finally figured out why it kept throwing the belt--idler pulley.View attachment 262969
The beauty cover is flopping around. The part that it hooks into is missing--I think.View attachment 262965
I miss my 10.5 Taylors :mad:.View attachment 262974
Of course if you yank them by the wire they'll break!View attachment 262973
This bare ended wire is just an extra ground I added. I don't have a big enough eyelet to add.View attachment 262972
I've had the best luck out the OEM wires. The ones that are actual OE, not just ACDelco brand or whatever.
Bear77
South FL
Very clean looking exhaust!
caprajohn
