George B
¯\_(ツ)_/¯
What if you only have one hand???Left hand used to open the door is LH swing and RH swing is right hand used to open the door.
Wrong
Haha
Bingo
Then I guess it’s a single hand swingWhat if you only have one hand???
ya it's like when they say "it won't start" ummmmmm what?, lolAlong those same lines, we should also define a standard for WTF "turn over" means. Does it mean that the crankshaft spins when the starter engages the flexplate or flywheel? Or, is it referring to the engine actually firing up after being spun by the starter? Some people say "the engine turns over but doesn't start" while others say "the engine cranks but doesn't turn over". Personally, I'd rather just banish the term from the database.
Super easy to replace once you have the transmission pulled away and flexplate removed.
For an in-car replacement, I highly recommend using a rear cover alignment tool. Might wanna check that oil pan gasket while you're there. Actually, the oil pan should go on after the rear cover, meaning it should at least be loosened to hang down a little as to not push upward on the rear cover while you're centering it. At that point, you may as well replace the oil pan gasket. Which, at that point, you may as well replace the oil pump pickup tube O-ring.
Youre right, it’s just not the way it’s described generally. Swing on.How can option 1 (mine) be wrong and option 3 (wjburken) be correct???
They are the same thing... lol
It's just a different way of describing the same thing.
I think that's what makes me the most nervous, dropping the trans. That seems to be a pretty big process. I'm not quite sure what I'd need to do it.
I have been reading about the alignment tool. Is one better than the other? I have seen two, plastic and billet. I am planning on doing the oil pan gasket because I thought it may be the culprit. I saw a video of where there is two long bolts that bolts up into the rear cover or something like that. I agree, the oil pickup tube O-ring will also be replaced since I'll be dropping the pan.
Are there any special tools required to do this?
Thanks
Yes
if you want, hit tow haul button while idling and watch gauge. It creep right up to the middle and hang there.
Yesterday it was probably charging and today it doesn’t need much. It will go up when needed.
Takes a few but it turns off the rvc so when you have a trailer hooked up (with a house battery) it charges that battery. How long did you watch?
