Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
yates ™
Resident Apple hater
Iowa
Mold this into that cubby between the power ports, angled up at you:
If it interferes with the traction control button, just tuck it inside the dash. Unless you use it?
Move the rocker switch you have in the cubby to the otherwise useless pocket next to the headlight knob.
This would also look good under the front cover so it is hidden when not needed, this is of it would fit.
I debated on commenting but it always caught my eye when looking at your day and not in a good way, more like out of place. I have built enough vehicles to appreciate a little honest feedback from another set of eyes. You have probably thought of this already but why not a gauge on pillar? It would be better vision for for you to see and look visually cleaner.
I have considered digital gauges but decided against them for this application due to the fact the pressure goes up and down by 5-10 psi or so when going over bumps and seeing the numbers constantly changing would drive me nuts. For tank pressure that would be ok but... then that gauge wouldn't match the look of the dual needle front/rear gauge. I was almost dead set on the pillar pod and I just decided on that route, I had to quit messing around and decide. so here it is; all from Glowshift. I just ordered it all. The dual gauges are digital input and the single is mechanical. I like the dual for the front/rear pressure. I'll run a 1/4" line from the tank for the single.
View attachment 241240 View attachment 241241 View attachment 241242 View attachment 241243
Hey, those match the factory gauges! Oh, wait... :p
They’re needed anytime I’m driving. I already have enough stuff to remember before driving or airing out, kind of a “pre-flight checklist” lol. Thanks though. I want my air info to be one of those things that’s up front and center so I don’t forget shit when I’m driving. I have sat at a left turn light and forgot to air the front up from 60 I use when cruising or sitting still to 120 for turning sharp until just before the front tires hit the fenders. Kinda important, I don’t want to replace front fenders again. Thanks for the ideas though.
Actually the Esky gauge faces ARE black and the needles are blue. So they match pretty good. I can set the color of the Glowshift to any color I want so if they look better green like those in the pic .. haha yeah right
And I see the confusion I set forth regarding digital gauges since I originally said I was considering doing a digital setup. I didn’t mean digital readout but digital signal instead of airlines going to mechanical gauges. I want to eliminate the 2 airlines going to the dual gauge for 2 reasons- leaks and the fact that it’s a ***** to run air lines to the a-pillar. If a matching single gauge was available in digital like the dual I would do that. I figure I can run a single line to the pillar. 3 lines would not have been fun.
Just wanted to throw it out there.
Your pillar idea was what I was thinking, just needed to quit procrastinating and make up my mind. Anyway, this is what I’m doing for now. It can all be changed if I don’t like it but I hope it looks good.
Probably gonna need a triple gauge pod anyway with what I’ve been thinking about...:rolleyes::cool:
......boost?
yates ™
Iowa
I have an idea floating around in my head for my caddy interior that some won't like, I am not even sure if I like it, but sometimes you just gotta try something and see how it turns out.
Off Road Pedia
