Random shots of the process:
Gutted front:
Traced the slot in the Belltech alignment cam with silver Sharpie to mark where the frame slot will be elongated:
Used cheap set of rotary rasps from Harbor Freight. Surprisingly, I did all eight slots with this one bit. It was pretty worn and cut much slower on the last few, but still did it. I also had to switch to a right angle drill because the angle grinder fell apart.
Elongated slot:
New control arm with factory cams:
I wanted to use the factory alignment as a baseline which would be lost with the Belltech cams. So I marked the positions of the original ones before I removed the old control arms. I also kept the original cams in their original order after removing them. After elongating the slots, I reassembled everything with the old cams and turned the bolts to position the new arms per the original alignment marks. Then, I carefully removed one bolt at a time to reinstall them with the Belltech cams. The frame mounts were tight enough to keep the arm in position while I removed and replaced the bolts. With the BT cams in place, I marked them so the baseline would be maintained as a reference.
I cut a piece of angle iron to span the lips of the wheels, vertically across the middle, and stuck a magnetic angle finder on it to measure the camber before and after the spindles and control arms were replaced. The spindles caused a lot of toe out and about 1/2" total narrower track width. I've got the toe pretty close and it tracks mostly straight. The steering was overly responsive, so I dialed in some positive caster. The steering wheel at first was at about 9 o'clock and is now around 12:15, so I went a hair too far. But, it's completely driveable and will be fine-tuned during and after Phase 2.
lowh07
Finally fixed the broken applique. Also cleaned up all of the caked on dirt behind the handle and installed an aluminum bowtie. It rained today so it’s a bit dirty in the pic. Removed the useless handle thingy on the back window.
Ordered some white vinyl and I’m going to wrap the fake wood next weekend probably.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Gutted front:
Elongated slot:
o_O:confused:
CHOO CHOO
BackPagePhil
Manheim, Pa
Roof racks don’t leak, there’s no holes in the roof where they’re attached. Its usually the shark fin antennas, they do have a hole through the roof where the cable goes through.
Any word on this? Did you do any digging to find the source?
CHOO CHOO
BackPagePhil
Manheim, Pa
Happy Thanksgiving to everyone. Went outside to move her and just saw this leak. This is the first real rain we have had in San Diego in over 6 months. Checked the roof rack and it’s tight. No noticeable rust holes. Any clues?
Kee Fuller
las vegas
Just held on by 3m tape? The useless handle thingy that is.
Belltech makes alignment cams that provide 1 degree of additional positive camber adjustment beyond where the factory adjustment slots and cams max out. You elongate the slots to let the bolts come outward more for the extra positive camber, and the BT cams are clocked differently to allow the adjustment. When you lower by altering the spring height, you usually get negative camber and there may not be enough adjustment in the stock setup to correct for it. I'm only dropping it 2" with my struts, which may be within the factory adjustability. But, for $25 and since I was gonna have everything torn apart, the cams are cheap insurance that I'd be able to align it.
Belltech cams (the 8 at the bottom, not the offset bushings and install tools)
wjburken
Eastern Iowa
Be warned: I punch my shower curtain before using the bathroom.
LOL! That reminds me. My wife’s mom was so paranoid that someone would be in the house if her Dad wasn’t home when she got home that her mom would grab a kitchen knife and open all the closet doors and jab the knife into the closet a couple times just to make sure and then she would do the same thing with the shower curtain. No idea how many articles of clothing showed up with mysterious cuts in them.
Lol
That'd be hilarious to see... Peeking in at her through a window, of course. Closet stalking isn't really my thing- too risky.
wjburken
Eastern Iowa
Lol
Yeah it was quite the site, my wife had told me about it and the family liked to give her a hard time but I still didn’t want to believe that it was a regular thing. Then I saw her grab a knife as my wife and I walked into the house after her and after watching her check the first closet, I told her to give me the knife and I’d check the rest of the house for her. I guess every family has some level of crazy in it.
One time my brother in law was the last person out and he put a couple balloons in the coat closet and when they got home, she took the knife as usual and hit one of the balloons and about crapped herself and my wife and her brothers were laughing hysterically. She was pissed!
wjburken
Eastern Iowa
Not today but Thursday night, I dug out the retractable cover that I had from a previous Yukon, that goes between the back seats and the rear hatch and installed it per my wife’s request so she could hide stuff under it while out shopping. Now I remember why it was up in my garage for the last 9 years.
89Suburban
SE PA
Why? I want one of those for mine. Sick of using a blanket.
Mountain Rambler
