Gruven heater core T-connectors
kbuskill
kbuskill
NE. FL.
I don’t understand why they didn’t just make the nipples longer in order to accommodate better clamps. One is long enough, why not the other 2?
This was discussed and Paul asked me if there was room... I told him that the two larger ones could probably be extended but the smaller one that feeds the rear heater core might pose a problem.
As it is right now, it already pushes the rear metal lines back toward the A/C accumulator so not a ton of room without possibly bending/massaging the lines.
All of this talk about clamps and what not.... in all truth the coolant system runs less than 20psi, more like 15psi, so it's not like you have to over tighten the clamps for fear of it blowing a line off.
Worm clamps are not my favorite but I will take them all day long in this application VS the plastic T-connectors. My 2 bits.
Sam Harris
Way off topic, but I’m not talking about clamps.. so.. do the Gruven mirror gears work on the gmt800 or only the gmt900? Looks from their site, like they’re specific to the gmt900 platform.
kbuskill
kbuskill
NE. FL.
My guess is they are GMT900 specific or else Gruven would market them for both. Give Paul at Gruven a call or send him an email and I'm sure he can give an answer with certainty.
ivin74
05 NBS Nali
Htown, Texas
I think they work on the gmt800, @Rocketman did you install the Gruven heater core T-connectors on your SUV?
Geotrash
Dave
Richmond, VA
Question for those who have used these Gruven tees. I see that they also now sell billet heater core couplers for these trucks. Should I buy them in addition to the tees? And what about the tee down near the water pump? Can the Gruven tee be used to replace that one too? 2012 Denali with rear aux heat.
19724A18-DAE5-41E2-89EB-40855E13E8B0.png C257A999-ED16-4EE3-A46B-1169869DA636.png
kbuskill
kbuskill
NE. FL.
View attachment 237890 View attachment 237891
The straight connector is not needed for trucks with rear heat.
You CANNOT use a Gruven T-connector to replace the Y-connector down by the water pump BUT you can buy the Dorman 626-553 which is a direct replacement made from aluminum. That is what I used.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/113134563530
The only way you can buy it is with hoses. They don't sell it separately, I called Dorman and asked.
Geotrash
Dave
Richmond, VA
Thank you, Ken! VERY helpful. I'll order the Dorman aluminum part with hoses as well.
Cheers,
Dave
donjetman
DARN,:( I wish I would have know about that Dorman hose Dec.24th when one of my plastic t-fittings broke. I had the GruvenParts.com aluminum t-fittings in hand, but I changed that heater hose with one from NAPA, and that Y fitting is plastic.:badidea: I'll buy the Dorman and install that aluminum y as soon as possible
Foggy
KS
Ok,, so I think i'm going to do the dorman part mentioned earlier for the
single Tee with heater hose assembly.
But, when I look up the heater hose Tee , they list one that's 111 MM and one that's 113 MM... How do I know which I have (without disassembly first). I have 2014 Yukon XL Denali
Thanks for the help!!
BrainDead
Hey Ken will this work on an 07 esky? I just ordered my gruven T's and will be putting them in soon
Kee Fuller
las vegas
I noticed the Dorman t connectors are 2 different types(1 is black the other is white) the gruven t connector fit both?
swat2380
How was the quality of everything else else like the hoses, clamps, plastic connection?
kbuskill
kbuskill
NE. FL.
I assume you are asking about the Dorman part... everything seemed to be of good quality. I used the entire Dorman assembly... aluminum Y-connector, hoses, clamps... except for the plastic quick connect fitting that goes to the factory plastic T-connectors obviously .
BrainDead
Got my gruven T's installed today, had to trim the hoses up about an inch going to the heater core and actually had to trim back the hard lines going to the rear of the vehicle about 3/4". Other than that, it's a great product that's going to hold up well
I tried uploading photos, but they're too big and the site won't accept them
HeavyHoe03
