Replace , cap or cover GMT900 dash...?
bondservant2
After a year of searching I finally found the "right" Suburban 2500 for our family vacation vehicle. A one-owner 2011 Suburban LT w/LT3. 128k-mile Texas truck in very good condition. It does have a pretty badly cracked dash so the question is to replace, cap or just cover the existing dash..? I was quoted $1100 for a factory replacement - which isn't terrible I guess. But if it's just going to crack again I don't want to do that.
What have you folks done for this issue...? Also is the cracked dash a safety issue in any way...?
Thanks in advance for your replies.....
they all crack, it has not been determined to be any kind of safety issue, there is a updated dash design and I would advise adding additional supports in key area's then it should be fine, did the $1100 quote include install? because if not that price is absurd
B
bondservant2
Price quoted was installed....
Stingraysktm
I'm interested in this as well. I just bought a 2014 Tahoe that has a cracked dash. I got it from a chevy dealer and they agreed to install a cap on it, I'm waiting to get it back and see how it looks.
Big Mama
Virginia
There are some caps out there that cover everything including around the nav and glove box so no seems show. There was just a thread on it but I can’t remember where they got it. Ugh
Any photos of the 2500 yet?
They've been popping out of the wood work around me lately. Saw two today, three yesterday and my daughter called me from work and said one was in her drive thru!
If it were me, I'd replace the dash with a new one. They cost about $400-500 and there are good videos on how to do it yourself by dealership technicians. Then I would cover it with a dash mat. Mine is not cracked and is covered by a dash mat.
I installed a new one in my 08 Silverado. About $450 for the dash itself but also the flat panel in front that goes next to the windshield was so brittle that it broke when removing it in order to remove the dash. That was another $300. The covers can look OK for most people I guess but they're not for me, plus if you ever need to remove your instrument cluster or the dash itself to get to , say, a hvac actuator or something else that's in there, that cover has to be replaced again since it's glued down.
2010gmcyukon
Midwest
Big Mama
Virginia
You’re probably right but the link brings you back to this thread
cfmistry
To me the stick-on cap is a no brainer. It takes 10 minutes to install, costs 1/3 as much as the replacement dash (1/4-5 if you are including labor), and looks 90% as good. Not as good as the original, but damn close. Even if you have to rip the dash apart and buy a new cover, it's less than half the cost of a new dash.
91RS
GA
I would just replace it. The caps are beyond ugly and look so cheap and half-***ed in my opinion.
WTSHARK
So. Cal.
Sitting, with the sun beating down onto it through the windshield takes a toll. Even if you're parking in garage at home, carport or other option... the dash is getting baked in UV. They shouldn't be cracking so soon, I have a 2015 with a flawless dash, but I also put sunshades up in the windshield whenever parked more than 30 minutes. It's gotten to be such a habit, the wife's doing it to hers as well. My 93 Crew Cab C3500, which I be-grudgingly sold in 2015 after buying the new Yukon XL, always had a dash cover. In the early to mid 90's when the "Sport Truck Craze" was in full swing, I bought that dash pad at one of the local Auto Swap Meets, it was "custom" designed for the dash, and had a Chevy Bow Tie embroidered on it. It fit like a second skin, was tucked into the dash/windshield seam with a spatula when I first installed it and aside from removing it once or twice to ensure the dash was still in great shape, was still on the truck when I sold it.
There's a lot to be said for a bit of forethought and protection. As asked previously, 1100, if installed seems not terrible. Or, purchasing a new one and installing it yourself after watching a few "Do-it yourself" (Youtube) videos is worth a shot-
I have a 2002 Denali and after 17 years it still looks new with no protection ever. It’s just a bad design on the NNBS or bad plastic. Not sure but a sunshade might save them. Too bad because you used to not have to worry.
Conedaddy
