Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
67RS427
maybe a set of MSD wires and Accel boot guards, plus getting headers ceramic coating.
I wanted to go with MSD wires but just heard about so many issues with them. I tried the Taylor wires and the Accel Ceramic ones are much better. You get a nice positive lock when clipped on so no need to question if they're on all the way. They can also literally lay on a header and not burn up.
*the problem with boot gaurds in my opinion is that it's a tight fit but the wire/boot doesn't touch. Then you add a boot gaurd that is big and bulky that literally lays on the header now conducting heat turning it into an oven. On my 427" BBC I tried that and kept burning up the boots even though they didn't touch.
Chrismnj
Chrismnj
NJ
how about spark plugs OEM? MSD Iridium Spark Plugs 37134 or ACDelco Iridium Spark Plugs 12680072 have good reviews.
01FormulaTA
NG. I don't have facebook. Think that's why? Maybe?
I don’t have FB and all the videos he has posted play fine for me...maybe it’s your browser?
I'm following your build closely, you are doing a lot of what I'm planning for mine this spring. I am still on the fence between kooks and American racing headers. Out of curiousity, what made you pick kooks?
Having owned both I would definitively conclude you can’t go wrong either way, one isn’t better than the other....think of it as like choosing between Lamborghini or Ferrari, there’s no wrong answer, neither has a clear cut advantage over the other
here are some side by side pics I took for comparison:
Top kooks 1 3/4" // Bottom ARH 1 3/4" (both for NNBS trucks and SUVs)
If anything I might give the slight design edge to ARH as you can see below on the passenger side header (1st pic) with the Kooks you have to route a starter ground wire (requires removing 1 bolt) through the primaries where as with the ARH design you never have to touch this wire and it already clears underneath the header, but then again when it comes to the y pipe design I prefer the Kooks Y as they offer a Y Pipe specific to the year model since they changed the cat-back connection between 07-08 and 09-14...Kooks offers 2 different Y Pipes where as ARH Y Pipe just comes pre fit for 07/08 and includes an adapter for the later years
67RS427
AC Delco for sure... As I mentioned, you may want 1 stage colder though and iridium doesn't do well for high cylinder pressure. Great for a 100k mile plug though
*start with an AC Delco LSA plug from a CTSv or ZL1 Camaro if you want OEM
Chrismnj
Chrismnj
NJ
ok just order the ACCEL ACC 9070C Extreme Ceramic Boot Plug Wire for GM LS Gen IV Engines will see how they fit, and since already have the AC Delco OEM plugs and ACDELCO D513A D510C Ignition Coil will put them in.
edit. also ordered
ACDelco 12673134 GM Original Equipment Engine Oil Pressure Sensor
Chrismnj
Chrismnj
NJ
Good morning, as the original thread title says I was only going to slap Supercharger on and call it a day, well this is quickly turning in to bigger project. Many of you have asked me about supporting mods, so I have put a list of all parts so far, I guess I will update this at later time as I am sure this list will grow.
1. Magnacharger TVS1900
2. BlackBear Tune
3. Airaid 202-270 AIRAID MXP Series Cold Air Dam Intake System
4. Kooks Y-Pipe 28553200
5. Kooks Longtube Headers 28502400, *ceramic coating
* Magnaflow exhaust already installed
6. Moroso 85481 Air/Oil Separator
7. Auto Meter 17118 Triple Pillar Gauge Pad
8. GlowShift Black Gauges
9. Accel 9070C Extreme Ceramic 135 degree boot Plug Wires
10. AC Delco 12673134 Oil Pressure Sensor
11. AC Delco Ignition Coil D513A
12. ACDelco 12617944 GM Original Equipment Exhaust Manifold Gasket
13. Stage 8 8900 Locking Header Bolt Kit for GM Small Block
* Considering valve-train upgrade.
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
@BlackBearPerf files E-Mailed toady, please let me know if its good.
Hey Chris, just looked at your email and it looks like you sent in a data log and engine stock tune file. That is what we need, but we will need the transmission stock tune file as well, you can retrieve that just like you did with engine file, but using the Read 2 function, instead of the Read 1 function, on the the AutoCal.
Chrismnj
Chrismnj
NJ
Hey Chris, just looked at your email and it looks like you sent in a data log and engine stock tune file. That is what we need, but we will need the transmission stock tune file as well, you can retrieve that just like you did with engine file, but using Read 2 function instead of the Read 1 function on the the AutoCal.
I believe I did read 2 as well email 3 files, if need it will do it again
Drewphil
