I really like the pillar pod setup. I wanted to do the same, but my gf said hell no. Where'd you get the pillar from? Never seen one like that before.
Wideband O2 Sensor Installed.
View attachment 213754 View attachment 213755 View attachment 213756 View attachment 213757
what gauges are there?
Where'd you grab the pod from? I like it!
Unfortuneately it won't fit my 03.Got it from amazon, I have 2 gauge pod for sale
Did anyone attempt or made some type of air tube to direct cold air from the front of the truck to the air box? like an air inlet in a bumper?
Lol. That’s what I was thinking too.That sounds more quiet than my stock exhaust! Is that a system or just the muffler? The pipe behind the exhaust tip looked like mild steel and not original.
The AirAid box I'm using has an extra inlet that pulls air from down below... I've never had an issue with water. I'm using just the box with a custom 5" MAF tube. The sound is great, even when the motor was stock.Did anyone attempt or made some type of air tube to direct cold air from the front of the truck to the air box? like an air inlet in a bumper?
Which style charger did you go with?
I should add that the filter is freaking massive. It's a 6" inlet on the filter...
https://www.airaid.com/mobile/product.aspx?prod=203-267
No top cover, just a rubber seal that seals it to the hood... In my experience, the ones with lids don't allow enough airflow through the small inlets, specially when the truck isn't movingIs there a top cover?
