Service Safety Restraint System error
kidtriton
Update on mine, 2021 Yukon Denali, started getting this message with around 150 miles on it. By 400-500 miles I could almost make it do it by leaning a certain way in the seat. Somewhere around 800-900 miles it stopped coming on and now with 1200 miles on it I haven't seen the message since. I've never taken mine in for fear of them wanting to keep it, I'd rather find it and fix it myself if it's a wiring problem.
ojet
My 21 Denali showed the message 4 or 5 times between 200 and 400 miles. @ 2000 miles now and message free.
Hannah Clampitt
Just picked mine up today - hope this actually fixes it. Fingers crossed!
jed2004
I was told mid-November for my part to arrive, but somehow it showed up yesterday ‍♀️. Service department assured me this is the correct fix. I hope they are correct as I’ve been without my Tahoe for 3 weeks and would like to actually drive it for a while :)
Toasty
The fact that 2 of you have the same fix and document procedure numbers seems like a good thing.
James Mill
Agreed on the two similar document numbers. Toasty and Jed, would appreciate you sharing g a follow up after a bit. I did not take mine in after all and decided to wait. This is hopeful.
Bigmanny
Bigmanny
I have had my truck back for 1 week and about 500 miles. No issues. I had the same work done, but they also replaced the airbag module and the connector. My dealer also had an issue with the zipper and that set them back a few days.
jed2004
If the light comes back on again, I will let you know! But hoping it does not :)
jasonblupa
I have airbag light on. Tried to replicate warning by moving around wires under the seat but it did not work.
Sent from my SM-G975U1 using Tapatalk
Dave Mathews
Took delivery of high country Tahoe yesterday. Half way home I got the message in picture. Dismissed it numerous time so got appointment Tuesday.
Toasty
I think it might be interesting to catalog build dates - at minimum the month is on the data tag on the door. If you have paperwork with the vehicle, it might have the actual build date
Mes14
New York
It’s been a week since the fix and no issues driven approx 400 miles
Update.. almost made it month with without this fxhking message now it’s back. I was warned here it wouldn’t last, Very frustrating
James Mill
Did you have a fix done? If so what? Sorry to hear about this.
Hondogreif
From 9/18, they reconnected a wire attached to the steering wheel airbag.
d67a76d0-8039-4afa-aed6-2f5512bcdef4-jpeg.257914
This was the fix for me if it helps. They also replaced the steering wheel air bag module as well. Has been close to a month and over a thousand miles and has not come back
Bigmanny
Bigmanny
Looks like 2 issues that people are chasing here the Driver seat airbag and steering wheel airbag/clock-spring. Mine was the airbag in the driver seat inboard side. The module and connector have been replaced. When they performed this work the seat cover has to be removed and it is zipped down so tight that multiple people have had the issue where the zipper is ripped off. It took 4 trips and my truck was finally in the shop for a few weeks for this, but I did have loaner suburban during that time period. It has been good for the past 3 weeks....back in for a different reason now.
venom260
NE Indiana
I finally got the SRS/Airbag fix performed on Tuesday! It was my third trip to the dealership for this issue. The bulletin the service statement refers to is: 1st trip-- Check module connector, disconnect/reconnect module. 2nd trip-- realign module connector, disconnect/reconnect module connector and use butyl tape. Those two "adjustments" to the SRS/Airbag module connector did not remedy the issue. Trip #3 replaced the driver's side airbag and replace the module connector. So far (knock on wood) no service SRS warnings! Let's all hope this is the final fix to this issue.
Other than that, we love this Yukon! My wife is the primary driver of this vehicle. My primary vehicle is a 2020 GMC Sierra Denali HD 2500.
Hope everyone gets this issue resolved soon!
James Mill
My light has come on three times now since I have had the clock spring replaced, but it is nowhere near as frequently as before and it seems to be more or less isolated. I have decided that I’m going to wait quite a while before bringing it in to see if they issue any sort of recall or definitive fix.
James Mill
The warning is light is back on in my truck. Anyone have a sustained, successful fix ?
ibarra503
