You don’t like the light bar?Ummmm.... Yes.
Post some pics once you get them and how bright they are. Been looking at the same ones for my Z71 Tahoe.That will take some work so for now I think I'll rock the light bar. It's been awhile since I could drive it due to the paint work etc. so after awhile I'll gather the stuff for the RGB panels. I need to do more research too. In the meanwhile I decided to buy the Morimoto LED fog lights. They're $210 everywhere I looked but there was a seller on EBay that I've bought from before who had a "make offer" listing so I offered $180, thinking he'd counter but he accepted. The billet grill will be here tomorrow so I'll get the bumper grill area done.
Will do. The other day when I went to get the truck from my painter he pointed out I was missing 2 trim pieces at the roof so after $40 here they are. One more thing the damn PO's painter left off.Post some pics once you get them and how bright they are. Been looking at the same ones for my Z71 Tahoe.
I like the lower led bar, but I like the solid bumper. Either way looks good tho.Here's a before and after front bumper conversion. There was a lot of bondo on the original; they had welded a flat piece of metal to cover both holes and then filled and sanded the whole thing. View attachment 205938 View attachment 205939
I’m def not putting those billet pieces back on the main grill. I cut the ones up that the truck came with and threw them in the trash. I can’t tell you how much time I’ve spent looking for diamond mesh that is even remotely close to the main grill. My thinking is maybe find a damaged HD grill at a wrecking yard because a good one goes for $150-$200 and I’m not paying that much to chop it up and possibly just destroy it. My other thought was either a solid black panel attached to the billet insert or find a way to attach the “ black/led “ panel I talked about before with either RGB led’s or an led bow tie behind it. The problem with the latter is mounting it. Also there’s a mounting problem with the factory grill mesh but I’m sure I could figure something out.The new bumper looks good, but I liked the solid bumper more. Too bad it wasn't done the right way.
As far as the grille stuff- There's too many patterns going on. I like the OEM crosshatch pattern and think it would look good in the small opening, even if you could only find grille material with the "diamond holes" were a little smaller. Or, you can cut out the OEM grille and put the same billet inserts there (Or is that where you're headed?).
Here's an HD grill from an nbs. Would that mesh work?I’m def not putting those billet pieces back on the main grill. I cut the ones up that the truck came with and threw them in the trash. I can’t tell you how much time I’ve spent looking for diamond mesh that is even remotely close to the main grill. My thinking is maybe find a damaged HD grill at a wrecking yard because a good one goes for $150-$200 and I’m not paying that much to chop it up and possibly just destroy it. My other thought was either a solid black panel attached to the billet insert or find a way to attach the “ black/led “ panel I talked about before with either RGB led’s or an led bow tie behind it. The problem with the latter is mounting it. Also there’s a mounting problem with the factory grill mesh but I’m sure I could figure something out.
IDK. Depends on the curve and the size of the mesh parts.Here's an HD grill from an nbs. Would that mesh work?View attachment 205941
If anyone knows if an 08 1500 bumper fits a 12 grill lmk. That’s what I originally wanted to do but my buddy said it wouldn’t work but he only does stock stuff. I just don’t like the HD bumper on a slammed truck because it has the big lower part that acts as a valance too that I had to leave off. That’s what leaves the big lower hole. I’ve read so much about it and some say it works but others say no.
