Pulled the driver seat to replace cushion. Question about the E Torx bolts
sparkvark
South Carolina
My 2001 Yukon needed to have the driver seat cushion replaced as you can imagine. With 412,000 miles it was a little flat. I got the seat out but one bolt gave me a hard time. The rear outboard 14 E Torx bolt didn't want to come out. I had to put a breaker bar and plenty of oil to get it out. The bottom threads must have been rusty since they go through the bottom of the floorboard. The threads are a little messed up on the bolt. The threads in the floor look ok but I am sure they could use some repair. Does anyone know what size they are and the correct chase to use? Or should I see if the dealer has replacement bolts and use a new one to chase the threads. Thanks in advance.
https://www.ebay.com/itm/00-14-SILV...703059?hash=item1f002974d3:g:l~MAAOSwkmZdWwfe
S
sparkvark
South Carolina
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
A 12mm tap with the same thread count and pitch should be easy to run down there and clean it up and the same for the chase of the threads.
S
sparkvark
South Carolina
I was wondering if I could do that. A chase will be hard to find in my area but a tap is easy enough to get. I will get one and gently try it.
S
sparkvark
South Carolina
May be able to rent them or us for free from a parts store.
Great idea. I had not thought about that. I just checked and our local Autozone has a thread chase set for loan. I will get it tomorrow. I will report back here with pictures good or bad in the next few days with my rebuilt seat installed.
Fless
Moderator
People's Republic of Colorado
Ouch! Those look worse than mine!!.
I called the local GM dealership. The bolts are a discontinued item but they were nice enough to give me the size. M12 1.75x45. It didn't list fine or coarse threads but I am sure I can find something to replace it with. I wonder what bolt strength these are. The dealer parts department didn't know that either.
I appreciate the listing.
The 1.75mm value in the bolt spec is the thread pitch. Besides the 12mm size, that's what you need to know to get the right tap/chaser.
Pretty sure they're grade 10.9. I'd replace it with a standard hex head bolt with some anti-sieze in the threads and paint the end that protrudes under the vehicle. You'll probably never be removing them again, but just in case and while you're there...
S
sparkvark
South Carolina
Thanks to everyone with their helpful tips. The job is complete and I am very happy with the results. Here are the pictures
Excellent work and documentation! You have added to our collective knowledge base. Thank you!!
S33k3r
Dallas, Texas
Wow! I have a Suburban that needs this so bad and I have been so chicken to do it, LOL. I kind of want to see if I can find superior foam for the seat, though, but it just may be that the foam I have is so old that OEM foam will be just fine. Currently, if you sit in the seat for any length of time, your backside starts to hurt. :(
CKendrick
