Gruven heater core T-connectors
kbuskill
kbuskill
NE. FL.
So your/gruven's design will allow me to hose and clamp all connections and eliminate all factory heater hose's up front with QD design?
Correct... I am currently running an aftermarket heater hose design with the factory plastic T-connectors. The aftermarket hose doesn't have the quick disconnect ends attached/crimped on the way the OEM hoses do.
Not the best pic but you can see the hoses are clamped onto the QD instead of crimped like the OEM hoses.
This pic may be a little better...
kbuskill
kbuskill
NE. FL.
Paul said he has 4 pre-orders so far.
He also said that if he gets more pre-orders it will speed up the process and if not then the next time their shop gets slow he will try to get some of these made up.
I told him that if he builds it, they will come... lol
Seriously though, I told him having pics of an actual part would probably help to attract more interest.
Ilikemtb999
Denver
Agreed, also sitting on $140 of mine is less enticing than seeing a product that actually exists and then buying it.
Ilikemtb999
Denver
Have you made a thread for the gmt800 section? They’re probably more likely to have this issue since it’s older.
kbuskill
kbuskill
NE. FL.
Ttt... is this ever gonna happen.... lol
Ilikemtb999
Denver
It’s killing me.... I want them before they break or before I pull my radiator for other mods.
08HoeCD
Work is busy so I’m not on here much and I just saw this thread. Speaking as someone whose original t-connectors failed and then the Dorman replacements failed within 6,000 miles, replaced with OEM, this custom metal solution is very attractive. I’m in at $59.99 each simply because I’ll never have to worry about the crappy plastic ones failing again.
I’m surprised more people aren’t jumping in on this. Think about how much you spend on non-essential stuff and how much you worry about changing oil every 3,000 Miles——-and then see yourself stuck with busted plastic t-connectors.
kbuskill
kbuskill
NE. FL.
This ^^^^^^^ in a nut shell !!!!
kbuskill
kbuskill
NE. FL.
Got this email from Paul @ Gruven....
Ken I know its been a while on these heater core quick disconnects.
We are up to 7 orders now so we are very close. Ive got it in the que at our CNC center so hopefully it wont be long now. If we can get a few more pre-orders then I can definitely push this up the chain and get it in work.
We are also going to make the pickup truck version of this as well, which is not a tee but a straight coupler. The tees are used on the SUV for rear heat where as the pickup trucks don’t need that so it’s a straight thru coupler but same idea.
If you know anyone with a pickup truck who is looking for a metal replacement for this please direct them to
http://www.gruvenparts.com/shop-by-car/gm-truck
These are the 7th and 8th items down that page currently.
FYI there are a number of threads now started on various forums regarding these quick disconnects. It seems to be a hot topic but many are content with just swapping plastic out over and over.
Here is a brief list of threads I know of that are discussing these, any help you can offer by chiming in on the importance of a metal version is appreciated and will help push this project along :
https://www.cadillacforums.com/foru...854-billet-heater-core-tees.html#post17624508
https://chevroletforum.com/forum/ta...ater-core-quick-disconnects-93538/#post367601
https://www.silveradosierra.com/engine/billet-heater-core-tees-t705052.html#p6990281
https://www.gm-trucks.com/forums/topic/217641-broken-heater-core-quick-disconnects/
Paul
www.GruvenParts.com
https://www.facebook.com/GruvenParts/
SOOOOOO.......
Looks like they should be coming soon I hope.
If any of you guys are members on any of the forums listed above please help spread the word.
Smrtss1
Any recent developments on this or are they just holding onto money for infinity?
jz57
Looked at that improved heater core T-connector, brought my attention to the rubber hose connection issue.
How does the "T" connect to front and rear heater Aluminum tubings, which have NO barbs; also the "T" connect has NO barb on its end toward hose from engine.
worleytrev93
