2021 Leveling/Larger tires
STORMIN08
wheel diameter CAN affect the outcome...the 22" offers a shorter stiffer sidewall thus not allowing as much flex and roll.
an 18" with that tire diameter could have some rub issues from tire flex.
olyelr
Elk Rapids, MI
Meh, when it comes to overall tire size and fitment from fenders etc., I wouldnt think the wheel diameter would play much of a role.
STORMIN08
fitment, not so much...that will be overall size.
the wheel diameter can have an effect on rubbing issues if tolerances are close. i wi;; post a pic of the upper a arm of a 17 bubr with a 22 ' wheel and 285 tire...if this were an 18" with the same you can see how addition flex may contact the arm itself.
20210131_164421.jpg leading edge of pic is tire sidewall...if it were a smaller wheel, the buble of the tire would be slightly closer to the arm ( bottom left in pic) and could flex more causing some rub
B_Falletta
Leveled today. For those looking to level, I installed a Motofab 1” strut extension. Anything more than 1” on these new Tahoe’s (at least the Z71) will put the front end higher than the back. This is within 1/8” of level per the dealership measurement. Have noticed no change in ride with the lower strut extension.
Looks good, brother! Quick question... I just bought a new z71 as well and ordered 22x9 OEM reps and 285/50r22 Toyo Open Country AT3s. I noticed in a previous post you didn't have issues with rubbing etc but you went ahead in leveled the front... if I do the same, which strut extension did you use and where did you order it from? You mentioned Motofab but when I go to their site they don't have a 1" extension for the 2021. Did you and can you use a different year/model etc? Also, did you have to run a spacer to clear the caliper? I ordered the Escalade reps (FR72 Factory Reproductions) and I'm worried I may need a quarter inch spacer since another guy who's running the same wheels on an RST had to.
DWSmoot
DWSmoot
Charleston, SC
I have noticed a very very slight rub now on fender well in reverse with wheel cut all the way. Nothing to be concerned with at all IMO.
Below is the link to the 1" level. I actually collaborated with an engineer over there before installing it. At the time there was nobody "listing" a 1" for the 2021. Dealer installed for me and said no issue with fit and function. Fit like it was on a 2020. I do not have Air suspension.
https://motofablifts.com/i-30558222...eveling-lift-kit-lm.html?ref=category:1390599
DWSmoot
DWSmoot
Charleston, SC
View attachment 270279 leading edge of pic is tire sidewall...if it were a smaller wheel, the buble of the tire would be slightly closer to the arm ( bottom left in pic) and could flex more causing some rub
Don't disagree when you are speaking to potential control arm rubbing. My initial comments were related to "fender" rubbing.
JTizzo
Looks great, and thanks for sharing all the info. Have you tried towing anything heavy; if so, any rubbing or heavy sag?
Bubba J Broussard
Non adaptive ride im guessing? Im having trouble finding anything for the adaptive ride version!
Xay2Smoove
