Official 00-06 Tahoe/Yukon/Escalade drop guide with pics...
04BUCKET
NORCAL SS - Can the BT shocks used when lowered be used before being lowered?
deepend
Kansas City
Mister H12
Model/Year/2x/4x/AWD:
- 2005 Tahoe LS 2WD
Advertised drop:
- 3"/6"
Fender height front/rear:
- 32.00/32.00
Front:
- LCA's : DJM 3" Drop
- UCA's : Stock
- Spindles : Stock
- Sway Bar : Stock
- T-bar keys : Stock
- Shocks : Belltech Street Performance
Rear:
- UCA: Stock
- LCA: Stock
- Springs : Norcal SS Custom 6" Drop Spring
- Panhard : Stock
- Sway Bar : Stock
- Shock Extenders : Yes
- Free Travel Mod : No
Wheels & Tires:
- Wheels : 18" Titan wheels, Powder Coated Black
- Tires : 265/60R18 Michelin Latitude Tour
Brief impression of setup:
NEED Free travel Mod (Ouch)!! Very noticeable change in handling characteristics. More of a "sporty" feel than a rocking boat. Takes curves like a dream, potholes.. not so much.
Future Modding:
Free travel mod.
Larger Sway Bars
Spohn adjustables.
22s
Etc..
Far from done but just had to jump on this post as soon as I dropped it! Too eager lol
Looks good man, i too have the same drop. But i went ahead and added the panhard bar and djm swaybars also did the free travel mod. How does yours drive? Mine is good except abit bouncy in rear. And thats without the bumpstops (removed). Hit me up.
Mister H12
Undercover Racecar
West Tennessee
It handles much better being low to the ground. I STILL haven't cut off the bumpstop brackets so the rear hits on big dips, just keep putting the project off. I'll be putting the panhard bar on for sure but I really want the full kit, just working on other stuff at the moment
chipf
Shorewood Il
2002 Tahoe
Front: Upper and Lower DJM control arms
Rear: DJM TB springs
Tire: 275/50/20
Front shocks: DJM
Rear shocks: Belltech Street Performance
DJM rear hardware kit and free travel mod
great looking truck. whats the drop on it ?
Thanks
nharkey85
Alabama
2005 Tahoe LS 2wd
22x9 et31 replicas
275/45 22 Hankook Ventus ST
NORCALSS custom 3/5-6 drop + extras
Ground to fender averages 32.25". Got a touch of chevy lean by .25". A tweak of the key might fix all that. Im almost positive im going down to 265/40 22 for the next set of tires. I need to do a little plastic trimming in the rear.
Front
DJM 3" drop LCAs
DJM UCAs
Belltech SP shocks.
Rear
Norcalss 6" spring
DJM trailing arm relocators
DJM shock extenders
DJM sway bar links
Belltech SP shocks
Spohn adjustable lower arms (delsphere joints)
Spohn adjustable upper arms (delsphere joints)
Spohn adjustable panhard bar
Free travel mod
Norcalss' rear bumpstops
Updated pics as of 2/11/15
OHSIXX
Milwaukee
06' GMC Yukon Denali
22x9 CK375's wrapped in 285/45/22 Bridgestone Duelers
Truck is stock minus the components listed below:
Belltech 2 3/4 Kit Ended up going no spacer so 2/4.
Details:
-New Lowering Springs(part of the kit)
-New 2" Drop Spindles(part of the kit)
-New DJM Rear End Links
-New Spohn Adjustable Panhard Bar
-New Axel Bumpstops
-New Shortened Autoride Links
-Completed FREE Travel Mod including grinding/painting
-Added Airlift Helper Bags 60742
Current Measurements(Ground to Fender Lip):
Front : 33 1/2"
Rear: 34"
sammy6659
Tahoe What's Stance
- 2005 Tahoe LT
Advertised drop:
- 3"/5"
-32.00/32.00
Front:
- LCA's : stock
- UCA's : stock
- Spindles : Mcgaughys 2" drop
- Sway Bar : Eibach
- T-bar keys : Gone
- Shocks :QA1 Coil Overs (custom brackets, etc) No more Tbars
Rear:
- UCA: Spohn adj.
- LCA: Spohn ajd. w/ Mcgaughys relocator kit w/ endlinks
- Springs : Beltech 5305
- Panhard : Spohn adjustable
- Sway Bar : Eibach
- Shocks : QA1 adj.
- Free Travel Mod - Yes
Wheels & Tires:
- Wheels : 20" GM SS chrome rims
- Tires : 285/50/20 Nitto420
Brief impressions of setup:
Rides good for being lowered. Firm setup, but handles 100x better. (with old setup)
How low is that....and would you be able to put 26s
Tahoewhat
Ballin' on a Budget
TX
It was about a 3 and 5 inch drop. I don't think you would be able to put 26' on it. 24's were close. With the right back space maybe but not sure.
scottierass
Hey to everyone on here I need some help from ya I got 305/45/22 on my truck I need to know how much can i drop it and what the best kit I can use and hope much it cost to do a job like this and when you drop a truck do it have the same driving like stock or is a bouncing feeling now please help love the set up on here
Sent from my SM-N900V using Tapatalk
Is that an HD grille on here? Did it just bolt right on?
Fosscore
@scottierass
HD grill indeed. Got one myself. It is a direct swap for the Tahoe only. Yukon needs fabrication work as the head lights are different. Has been done and looks sweet, but a bit more work than just a swap.
EKdenali
- 2002 Yukon Denali AWD
Advertised drop:
- 4"/6"
-31.00/31.50
Front:
- LCA's : stock
- UCA's : stock
- Spindles : Belltech 2508
- Sway Bar : Eibach 35mm
- Tie Rods : Illy Napa Premiums
- T-bars : stock w/Tahoe Z71 Bumpstops
- T-bar keys : 3/4 Ton Purple Keys
- Shocks : Bilstein HD OE Replacement Front/Bilstein 5125 21.54" Extended Length Rear
- Steering : Fabricating a Dual System
Rear:
- UTA : Stock
- LTA : Stock
- Springs : Belltech 4" Trailblazer 4230
- Panhard : Spohn Adjustable
- Sway Bar : Eibach 32mm w/Jeep Wrangler JK Links
- Shocks : Bilstein 5125 21.54" Extended w/Belltech 6651 Extensions
- Air Assist : Airlift Helper Bags 60748
Wheels & Tires:
- Wheels : 22x9 Gray TBSS
- Tires : Nitto 420S 285/40/22
Considered upgrades:
- Stock Keys decranked or DJM Arms because they're the only thing I haven't tried on this vehicle.
Trucks drives nice but is a bit stiff, comes with the territory being this low. The truck handles amazing for such a heavy vehicle. I have no issue pushing it hard through tight mountain roads faster than sense would dictate. I'd contribute much of the handling to the lower center of gravity, quality tires, and most notably the gigantic Eibach sway bars. The spohn panhard was an excellent upgrade and I'm considering some adjustable rear arms to center the wheel. Pinion angle for the rear axle is money though.
Pics:
I know this is old, but where did you order your parts. I love how you Denali looks!
Ambitious02
Southern Cali
Yes run a 285/40/22
Thanks bro!! Ok didn't think that through and just bought new tires but about to drop her!! Hopefully I can sell the new tires and go get the right size!!
Your drop is the exact stance I'm going for from this thread! Any other pointers you can give me when going that low? Like anything I need to look out for? How far did you have your keys keys turned down in the front? Also did you ever need or use a panhard bar?
NeverSatisfied
eBay Baller
Wichita, Kansas
Panhard bar is a must. Key was maxed out on pass side (as low as it would let me) and halfway on drivers. You'll need a belltech camber kit if your doing keys and spindles or you'll have problems with alignment
Ambitious02
Southern Cali
Ok cool, I'm doing just that so will look into that camber kit most def! Thanks for the pointers!! Ok I hear ya in regards to the panhard, will get that also! Want to be slammed but don't want it to be headache! I'll post up pics on here once she gets done! Going to take a bit longer since I have to get new tires!! :emotions122:
Ambitious02
Southern Cali
Oh what valance where you rocking on your Tahoe? I have a Yukon but it should work right?
Bentley95
