Dub Skillz '11 Escalade ESV
M1O9NSTER
New shoes. POW!!!!
285/45/22
Parada Spec X tires.
Wilwood 16" big brake kit
Belltech 2"/3" 753SP
Gangster as ph@ck now.
M
M1O9NSTER
woops! mods, please move to the lowly 2014 thread. sorry 2015+ folks!
You've got a nice start going here! :waytogo:
M
M1O9NSTER
Beautiful! How do they perform? Do you plan on adding the rear kit anytime down the road?
Performance is phenomenal. Factory brakes on these trucks are absolute garbage. With the Wilwoods, it's night and day difference. You can use these things repeatedly and aggressively without fade. With the current set up, it really handles more like a decent car than a 3 ton truck. I can totally recommend the 16" Wilwood BBK.
Eventually, I will do the rear set as well. My rule is, any part that wears out, gets replaced with a performance part. :) So when they tell me I can no longer pad slap the rears, It'll be time.
Clean07Burb
Nice. I'd love to upgrade my fronts to Wilwood's, but man, that $2k is hard to part with! For now I went with the Baer EradiSpeed +1 kit, which gave me a caliper relocation bracket and 15" front drilled and slotted rotors. Stops really good now, but I'm sure the Wilwood's would put them to shame. I'd love to drive someone's truck with the Wildwood kit. That would more than likely give me the push I need to just order the damn things and get it over with already!
---------- Post added at 02:38 PM ---------- Previous post was at 02:29 PM ----------
Also, if you're impressed with the current handling as you say, try adding a set of aftermarket sway bars. I just added a set of Eibach oversized bars with Energy Suspension polyurethane end links in the front and the correct shortened DJM links in the rear which reposition the sway bar and bring it back to the correct angle, and the difference in handling is literally night and day. With the bars, the 2/3 drop, the 305/40/22 Toyo Proxes ST2's, and new shocks and struts, my truck handles incredibly well.
M
M1O9NSTER
Forgot to mention, I did the Belltech front and rear sway bars when I dropped it. ;)
Yes it hauls balls around corners....for a big ass truck.
GalaxyBlackEsky
BlackedoutLT3
MD
Nice start. I love my Wilwoods. Like you said when stuff wears out its time for upgrades. I haven't done my rears either and prob wont. I might just do Baer 14's with stock calipers just to somewhat match.
M
M1O9NSTER
Any air ride suspension messages from that drop?
Yeah. Major service suspension errors with all passive components. Removed easily with a strutmasters module. Takes about 20 min to install with 4 positap connectors.
Drewphil
