Took the Oil Pan Off Yet Again
donjetman
3 summers in a row now since I started running Valvoline Premium Blue "Restore" 10w-30.
(not Valvoline Restore and Protect).
VPB Restore came about when Cummins asked Valvoline to come up with an oil that would cleanup the stuck piston ring problem they were having in one of their engines models and do it in one oil change interval. Its special and $80/gal.
Very little debris in the oil ban bottom this time, unlike the previous two times when there was a lot. I won't need to do this again.
While I'm in there this time I'm removing the pressure relief valve and shield and installing a Dorman #65407 plug in its place. My 2007 L92 didn't come with AFM hardware but it did come with that pressure relief valve?
Marky Dissod
Nice.
Nice.
Will you continue using Valvoline Premium Blue Restore, or will you switch to a different motor oil?
West 1
Just curious, why pull a pan 3 times in a couple years? If the oil pick up seal is good and it is not leaking that puppy stays on in my car as long as possible?
rdezs
I would say removing accumulated sludge is never a bad thing, particularly after extended use of such an oil. A clean engine is a happy engine :cool:
It's also good to see long-term results.... So we know it's not just snake oil.
rdezs
... And I would go ahead and replace that oil level sensor. They're inexpensive, plastic, that one looks like it's original?
donjetman
donjetman
Its not time for an oil change now, but when it is time I'll probably switch to either Amsoil, HPL, or VRP?
Marky Dissod
At $80 per gallon / $20 per Qt, you definitely deserve a break. I itch whenever I pay over $8 per Quart,
and I know that plenty of people pay under $8 per Quart for GroupIV synthetic often.
donjetman
donjetman
I know from spending a lot of time at BITOG forum that group IV is rare these days, not even a splash of group IV in box store "synthetics". :(
Yrs ago the law and industry started allowing group III GTL oils to be called "synthetic".
But Valvoline Premium Blue Restore is 80% group IV & V base stock.
JoeBlobs
Senior Member
NJ
Did you use Restore & Protect at all in this process or only the Blue Restore version?
Incredibly impressive results either way.
opfor2
Riverside County, CA
Wouldn't using a quality synthetic motor oil and then adding a bottle of Rislone engine treatment have been more economical with the same results?
BadDaddy2003
