Z55 Air-ride set-up removal
homesick
The Best Me I Can Be
Navy Air Force
My '07 Escalade came with the RPO-Z55 air ride set-up. A prior owner either replaced or by-passed the rear air-ride stuff.
I just read that there are one piece bypass modules that will prevent the suspension warnings from showing on the dash. The truck drives ok, I'd just like to stop the warnings.
Do y'all have any help with this?
Thanks
Here's one example...
homesick
homesick
Navy Air Force
They say they don't sell the module by itself. Any ideas from y'all?
joe
mikez71
I may need the same thing if/when my z55 shocks go out.. Don't know anything about the system yet...
BUT Amazon has a bunch of kits, looks like they spoof the shocks and ride height sensors..
homesick
homesick
Navy Air Force
I've been digging, and have found that a 3.9 ohm 25 watt resistor at each shock is supposedly the answer for "spoofing" the system to get rid of the suspension warning light on the dash; unless, of course, your truck suffers from some other cause, lol.
Anybody have any input on this?
joe
mikez71
measuring resistance of z55 struts won't work? And I wonder if they are different resistance compared to older z55 struts..
I'll measure my '05 if you measure your '07...
homesick
homesick
Navy Air Force
LOL, my crawling around under my truck days are all behind me.
I stopped and talked to my mechanic today. He had a general awareness of the resistor install solution, but didn't know any specifics. He's willing to try it though.
joe
SpareParts
North Idaho
homesick
homesick
Navy Air Force
(I don't know if I've said this yet, but my compressor does not work. I don't even know if it's still there.)
So any way, thanks man. I'm saving this but, again, I'd feel better if the resistors' specs were given.
I suspect that even if they don't do what I want, they can't do any harm; but I'm no electrician. Can any of y'all confirm that guess?
joe
homesick
homesick
Navy Air Force
Could be wrong but i seem to remember someone saying to remove the fuse for the compressor and the message will go away?
Yeah, I've already read a few variations of that- do the compressor, do the shocks, and do both.
Fuses have come up once or twice now, so does anyone have solid knowledge about them?
joe
homesick
homesick
Navy Air Force
Confirming that 3-5 Ohm 25 Watt resistors will do the trick to eliminate the dash warning. If the compressor fuse is still in place, remove it.
What about a resistor for the [missing or disconnected] compressor; with or without the compressor fuse installed?
joe
joe
With a resistor on each of the 4 shocks electrical connectors, and the compressor fuse pulled, you should have no dash warnings.
homesick
homesick
Navy Air Force
I read, a time or two, about top speed being limited because of this topic. Do any of y'all have anything on that?
I'm just curious here.
joe
mikez71
My factory ECM was limited to 98mph.. So you'll need that tuned first..
I think if there is a fault in the suspension system, there maybe another speed limiter..
But since you're tricking it, shouldn't be an issue.. ?
1948Buickroadie
